Results 1 to 4 of 4
Thread: sql database problem
01-01-2010, 21:32 #1
-= TeamSpeak User =-
- Jan 2010
- Location
- canada
- 4
Edit by mod
Please don't use this outdated script anymore! The script got an overhaul long time ago.
Please use the minimal or startscript instead
This is on a freshly installed Debian system with both mysql and sqlite installed I tried following several peoples walkthrough and none work exactly
I have 3 possible outcomes when I try to start TS3 server the first one is when i just execute it with no parameters
The next is when I load the ts3server.ini filtts@thethreat:~/teamspeak3-server_linux-x86$ ./ts3server_linux_x86
Logging started
2010-01-01 21:14:26.521128|INFO |ServerLibPriv | | Server Version: 3.0.0-beta12 [Build: 9596]
2010-01-01 21:14:26.523471|INFO |DatabaseQuery | | dbPlugin name: SQLite3 plugin, (c)TeamSpeak Systems GmbH
2010-01-01 21:14:26.524564|INFO |DatabaseQuery | | dbPlugin version: 3.6.21
2010-01-01 21:14:27.660431|INFO |Accounting | | Licensing Information
2010-01-01 21:14:27.664493|INFO |Accounting | | type : Non-profit
2010-01-01 21:14:27.667837|INFO |Accounting | | starting date : Wed Dec 30 16:00:00 2009
2010-01-01 21:14:27.670883|INFO |Accounting | | ending date : Thu Dec 30 16:00:00 2010
2010-01-01 21:14:27.674054|INFO |Accounting | | max virtualservers: 10
2010-01-01 21:14:27.677096|INFO |Accounting | | max slots : 512
2010-01-01 21:14:27.780056|INFO |FileManager | | listening on 0.0.0.0:30033
2010-01-01 21:14:27.990207|INFO |VirtualServer | 1| listening on 0.0.0.0:9987
2010-01-01 21:14:27.995076|INFO |Query | | listening on 0.0.0.0:10011
^C
And last when I try to load both the ts3server file and the ts3db_mysql filestts@thethreat:~/teamspeak3-server_linux-x86$ ./ts3server_linux_x86 inifile=ts3server
Logging started
2010-01-01 21:14:37.868691|INFO |ServerLibPriv | | Server Version: 3.0.0-beta12 [Build: 9596]
2010-01-01 21:14:37.870603|CRITICAL|DatabaseQuery | | unable to load database plugin library, halting!
I beleive the last option takes me closest to starting the program but i have tryed several different database name and none seem to worktts@thethreat:~/teamspeak3-server_linux-x86$ ./ts3server_linux_x86 inifile=ts3server dbplugin=ts3db_mysql
Logging started
2010-01-01 21:14:43.847438|INFO |ServerLibPriv | | Server Version: 3.0.0-beta12 [Build: 9596]
2010-01-01 21:14:43.854698|INFO |DatabaseQuery | | dbPlugin name: MySQL plugin, (c)TeamSpeak Systems GmbH
2010-01-01 21:14:43.855800|INFO |DatabaseQuery | | dbPlugin version: 1
2010-01-01 21:14:43.876877|ERROR |DatabaseQuery | | mysql_real_connect() failed with error: Unknown database 'test'
Segmentation fault
my ini files are as follows
ts3server.ini
ts3db_mysqlmachine_id=
default_voice_port=8801
voice_ip=70.74.197.59
licensepath=
filetransfer_port=30033
filetransfer_ip=70.74.197.59
query_port=10011
query_ip=70.74.197.59
dbpluginparameter=
dbsqlpath=sql/
dbsqlcreatepath=create_mysql/
logpath=logs
logquerycommands=0
<blank line>
So is there a database name I should be using or do i need to make a new database name in mysql[config]
host=localhost
port=8801
username=tts
password=
database=test
socket=
<blank line>Last edited by dante696; 21-02-2011 at 12:14.
02-01-2010, 00:56 #2
-= TeamSpeak Addict =-
- Sep 2006
- Location
- Germany / Hannover
- 133
maybe it is usefull to write the right name from the inifile to the commandline
./ts3server_linux_x86 inifile=ts3server.ini
02-01-2010, 01:46 #3
-= TeamSpeak Lover =-
- Jan 2010
- Location
- In front of my computer
- 53
Create your database
You need to create your database, and the user account. Then use that database in your INI.
Assuming you have mysql on the same box as TS3...
Code:mysql -uroot -p <<<Login as root>>> CREATE DATABASE ts3db; CREATE USER 'ts3dbUser'@'localhost' IDENTIFIED BY 'xPVHFxL7zUnZPReH'; <<<Make up your own password>>> GRANT ALL PRIVILEGES ON `ts3db` . * TO 'ts3dbUser'@'localhost';
Then your ts3db_mysql.ini should be...
LinuxxCode:[config] host=localhost port=3306 username=ts3dbUser password=xPVHFxL7zUnZPReH database=ts3db socket=
02-01-2010, 02:15 #4
- Jan 2010
- Location
- canada
- 4
I solved it first i had to delete the ts3server.ini file and have the program remake it with the command
then I used vim to add my ip address to the file and the command./ts3server_linux_x86 createinifile=1
and it worked./ts3server_linux_x86 inifile=ts3server.ini
Howto: TeamSpeak 2.x mit MySQL-Server 5.x
By DaFox in forum [TeamSpeak 2] Server SupportReplies: 27Last Post: 18-08-2009, 02:51 -
SQL not found problem
By maxkrey in forum [TeamSpeak 2] Server SupportReplies: 3Last Post: 20-02-2008, 14:05 -
MySQL scripts
By BigF00t in forum [TeamSpeak 2] Server SupportReplies: 2Last Post: 13-02-2008, 21:07 -
MySQL-Scripte fehlen
By sighn in forum [TeamSpeak 2] Server SupportReplies: 3Last Post: 13-02-2008, 16:11 -
OpenSQL Error: SQL logic error or missing database in query: 18
By [Merlijn] in forum [TeamSpeak 2] Server SupportReplies: 1Last Post: 03-03-2003, 16:41
