Results 1 to 12 of 12
Thread: Permission system Crashing
02-01-2010, 02:00 #1
-= TeamSpeak User =-
- Dec 2009
- Location
- Reeds Spring, MO
- 10
x32 Beta12 is crashing the server when you edit user permissions..
2010-01-02 00:26:22.576556|CRITICAL|DatabaseQuery | | setSQLfromFile( file:sql/group_member_detail_get_by_groupid.sql) failed
Looks for a fix..
02-01-2010, 02:49 #2
- Dec 2009
- Location
- United States
- 23
Same thing here Beta 12 x64
[code]2010-01-02 02:36:15.956101|CRITICAL|DatabaseQuery | | setSQLfromFile( file:sql/group_member_detail_get_by_groupid.sql) failed[/quote]
02-01-2010, 11:41 #3
- Jan 2010
- Location
- Germany
- 1
2010-01-01 22:09:42.661549|CRITICAL|VirtualSvrMgr | | Assertion "m_pVirtualServerData->getFailedLocks() < 100" failed at server/serverlib/virtualserver_manager.cpp:1024;
and sometimes 2009-12-31 13:45:06.523035|CRITICAL|DatabaseQuery | | setSQLfromFile( file:sql/group_member_detail_get_by_groupid.sql) failed
and in one log is 2009-12-31 12:50:21.053333|CRITICAL|PktHandler | 1| Assertion "connection.get() != __null" failed at common/packethandler.cpp:447;
I get this error message in my logs and then server crashes.
Crashes are happening sometimes (when editing permissions and trying to browse upload channel). Maybe its random crash dont know!
Server: Beta12
Running on Debian 5.0 Lenny 32-Bit
After crash my Server gets very slow!!Last edited by IxDe65; 02-01-2010 at 18:33.
02-01-2010, 13:51 #4
- Dec 2009
- Location
- Reeds Spring, MO
- 10
Seems to be a serious issue with no word from TeamSpeak.
02-01-2010, 15:16 #5
-= TeamSpeak Addict =-
- Dec 2009
- Location
- Bergen, Norway
- 118
Same error on my server beta12 edition.
Using built in database and not mysql
03-01-2010, 17:28 #6
- Jan 2010
- Location
- Michigan
- 11
Fix for the crashes
I was using beta 9 of the server without an issue. I upgraded to beta 12 and now anytime I go into group permissions the server immediately crashes with the following error.
I tried with a fresh DB and with the original. Both had the same isue.
Upon looking a little deeper it seems that the file "sql/group_member_detail_get_by_groupid.sql" doesnt not exist. I reopened the archive, extracted out the SQL files, replaced the ones in the folder with the updated files and was then able to edit the system permissions. No more crashing!
Machine:Code:2010-01-03 17:09:36.353097|CRITICAL|DatabaseQuery | | setSQLfromFile( file:sql/group_member_detail_get_by_groupid.sql) failed
No INI file used
Fedora Core 11 x 64
4 gb ram
500 gb harddrive
Visad
04-01-2010, 23:37 #7
- Dec 2004
- Location
- Germany
- 14
pls repair this bug on the next beta
05-01-2010, 05:49 #8
-= TeamSpeak Team =-
- Jun 2002
- Location
- Krün / Germany
- 1,965
it would dramatically help if you would also copy over NEW sql files and not just update a binary...
05-01-2010, 08:15 #9
- Dec 2009
- Location
- Bergen, Norway
- 118
06-01-2010, 18:34 #10
- Dec 2004
- Location
- Germany
- 14
06-01-2010, 19:23 #11
- Dec 2009
- Location
- Good old Germany
- 222
copy all files from the new beta and overwrite all files. Thats all.
cheech
06-01-2010, 20:08 #12
- Dec 2004
- Location
- Germany
- 14
[Guide] Permission System
By Soljia in forum Permission SystemReplies: 4Last Post: 27-01-2010, 10:08 -
Permission System, best i have ever seen
By BuffBot in forum Suggestions and FeedbackReplies: 9Last Post: 09-01-2010, 21:05 -
Permission system is inconsistent
By AlphaWolf in forum Permission SystemReplies: 0Last Post: 21-12-2009, 03:56 -
Linux TS2 Server läuft, webinterface "superadmin" tuts,Server gestartet aber conerror
By lxphat in forum [TeamSpeak 2] Server SupportReplies: 8Last Post: 15-10-2009, 18:48 -
please help someone
By theundead67 in forum [TeamSpeak 2] Server SupportReplies: 59Last Post: 31-03-2007, 04:53
