Results 1 to 7 of 7
Thread: Problem with connection
04-01-2010, 18:15 #1
-= TeamSpeak User =-
- Jan 2010
- Location
- Italy
- 5
hello everybody!!
so i have a big problem with TS3.
i have installed server but anybody can connect with me
i search in the forum and i have open the port, firewall and modem, but nothing.
everytimes the same message with failed to connect
so i don't understand the problem
i love teamspeak and i want use ts3 because it's very good, but how i can?
04-01-2010, 19:50 #2
-= TeamSpeak Team =-
- Jun 2008
- 7,764
Do you mean can't connect?
Did you gave them your IP from global internet? and not 192.168.0.xx or 127.0.0.1.
Try this given IP http://whatismyipaddress.com/
04-01-2010, 20:41 #3
- Jan 2010
- Location
- Italy
- 5
yes my ip is correct, i have already take it from web.
i try also i have install hamachi for have always the same ip.
the problem is that in ts2 sever all member can entry and in ts3 no
the answer is:
Failed to connect to server
04-01-2010, 21:06 #4
- Jun 2008
- 7,764
What port's did you open?
04-01-2010, 22:07 #5
- Jan 2010
- Location
- Italy
- 5
hi
i open port 9987, tcp and udp
i use 9987 as port
04-01-2010, 22:39 #6
-= TeamSpeak Addict =-
- Dec 2009
- Location
- florida
- 261
i tried everything i could find here on the forums to get my home ts3 server setup to be able to connect from internet/external ip. DMZ, applying the external ip to the internal ip in modem settings. nothing
windows xp pro 32 bit
Fios modem/router
what worked for me.
forward in the router...
UDP 9987
TCP 10011
TCP 30033
bind the ts3 server to the internal ip (ip server computer is assigned from router)
ts3server_win32.exe" voice_ip=xxx.xxx.xxx.xxx query_ip=xxx.xxx.xxx.xxx filetransfer_ip=xxx.xxx.xxx.xxx
x = my internal ip
most people on this forum say there is no need for this, but its the only thing that worked for me
i have run BF1942, BF2, BF2142, ventillo, FEAR and TS2 servers from home here.
all have worked just fine doing simple port forwarding.
TS3 is the first i had to bind to an ip.
look though all the other "cant connect" post and see what you can find
05-01-2010, 10:29 #7
- Jan 2010
- Location
- Italy
- 5
hi
so for to give more information,
when i start server it give me again no console logging under windows.
and i look the log files when there is write:
08:07:29.203125|INFO |FileManager | | listening on 0.0.0.0:30033
08:07:29.390625|INFO |VirtualServer | 1| listening on 0.0.0.0:9987
08:07:29.390625|INFO |Query | | listening on 0.0.0.0:10011
you think that maybe is here the problem?
TeamSpeak 2 Anti-Flood Daemon
By ScP in forum [TeamSpeak 2] Addons & ScriptsReplies: 193Last Post: 07-09-2009, 18:27 -
Newbie problem: Can't get UDP connection, home server
By Voyager in forum [TeamSpeak 2] Server SupportReplies: 3Last Post: 02-06-2009, 21:03 -
Strange problem: connection timed out
By Nixaerie in forum [TeamSpeak 2] Client SupportReplies: 1Last Post: 09-09-2008, 23:04 -
Problem Hosting Server on computer running ICS (Internet Connection Sharing)
By computerspazzz in forum [TeamSpeak 2] Server SupportReplies: 2Last Post: 17-04-2004, 18:53
