Results 1 to 8 of 8
    Jan 2010
    Germany, Bavaria
    13
    5 little Problems
    Hi
    Im already done with my new TS3 style, but i cant finish it till these problems are solved
    I hope one of you can help me, i can also send you my source code if needed.
    I really dont know what i did wrong.
    Just look at my picture:
    1) If i use an image as selection bar, the small icons merge with words. If i use normal bars (not as image) it doesnt happen. Maybe i have to work with layers?!
    2) this damn menu bar doesnt wanna change its color, whatever i try. which commands should i use?
    3)I want to exchange these white border with the dark one in the green field.
    4) How can i change the colors of this tabs?
    5) my horizontal scroll bar doesnt work... it can be moved in 1 direction only and doesnt show the background / scroll botton and the right arrow botton.
    I know my decription is very simple, but maybe anybody can give me a hint
    Thanx a lot
    Robertdehero
    http://www4.pic-upload.de/05.01.10/w5c2ynbblfvc.jpg
    Dec 2009
    Sweden
    34
    Hi, if you provide a screenshot I think you'll get help easier.
    I have changed the menu bar and the tabs in my qss file: http://forum.teamspeak.com/showthread.php?t=49056
    Download and edit it, it's short and you'll find the parameters quickly.
    Jan 2010
    Germany, Bavaria
    13
    sry,
    thats the link to the picture
    Oh and btw i got this skin already. I use the same code for the Menu tab, but it doesnt work :S
    Oh and i meant the Menu tab with CONNECTION / BOOKMARKS and so on.
    Dec 2009
    Sweden
    34
    Aaah. Let's see: (these are unchanged, change accordingly!)
    1. Menu Bar:
    Taken from BlueSky.qss, has a gradient so you have to edit that out.
    /* MenuBar */
    QMenuBar {
    	background: qlineargradient(x1: 0, y1: 0, x2: 0, y2: 1, stop: 0 #6a96b9, stop: 1 #c2d7e1);
    	spacing: 2px;
    	color: #000;
    QMenuBar::item {
    	color: #000;
    QMenuBar::item:selected {
    	background: qlineargradient(x1: 0, y1: 0, x2: 0, y2: 1, stop: 0 #a5d3e8, stop: 1 #e9edef);
    	color: #000;
    QMenuBar::item:pressed {
    	background: qlineargradient(x1: 0, y1: 0, x2: 0, y2: 1, stop: 0 #c2d7e1, stop: 1 #e9edef);
    	color: #000;
    4. Tab bar:
    Taken from my own skin's qss-file, needs changing.
    /* TabBar */
    QTabBar {
    	background-color: #202120;
    	margin-bottom: 4px;
    	margin-top: 4px;
    	padding-top: 3px;
    	padding-left: 3px;
    QTabBar::tab {
    	background-color: #222221;
    	border: 1px solid #000;
    	color: #fafade;
    	min-width: 8ex;
    	padding: 3px;
    	padding-top: 3px;
    	padding-left: 6px;
    	padding-bottom: 3px;
    	padding-right: 6px;
    QTabBar::tab:selected {
    	color: #fafade;
    QTabBar::tab:hover {
    border: 1px solid;
    border-color: #fafade;
    	color: #fff;
    	border-color: #000;
    	border: 1px solid #fafade;
    QTabBar::tab:selected:top {
    	border-top-color: #fafade;
    	margin-top: 3px;
    QTabBar::tab:selected:bottom {
    	border-bottom-color: #fafade;
    QTabBar::tab:!selected:top {
    	margin-top: 0px;
    QTabBar::tab:!selected:bottom {
    	border-bottom-color: #000;
    	margin-bottom: 0px;
    Jan 2010
    Germany, Bavaria
    13
    Thanks a lot, so my style looks now:
    http://www4.pic-upload.de/05.01.10/98ejf5oqnevt.jpg
    I only need to make the borders black or something else.
    And i still got the problem with the menu bar from the drop down menu (Connection - Bookmarks etc.). I havent found a way yet to use a graphic as bar without errors.
    But im sure there is a way^^.
    Wow my first own style will be finished soon.
    Dec 2009
    Indiana
    50
    Check to see if the horizontal QScrollBar add-line and sub-line says width and not height. One of the qss files I looked at recently said height where it should have said width and this would cause the situation you mention.
    Jan 2010
    GER
    99
    Thumbs up
    looks cool would like to see a DL link soon
    Jan 2010
    Germany, Bavaria
    13
    Quote Originally Posted by BGen_JD8 View Post
    Thanks for this hint, i have compared my command lines with bluesky.qss and now my scrollbar works fine
    @BetaAlien: Du hast genau den richtigen Namen fürn Beta-Tester ^^.
    Ja ich hoffe, dass ich bald fertsch bin. Dann darfst Du ausgiebig testen
    Vielleicht hast du ja auch ne Lösung wie ich im Drop-Down-Menü den Auwahlbalken so als Grafik einfüge, dass es keine Fehler gibt (siehe Link im ersten Posting).
  1. Sound and overall problems with TS3
    By armyman77777 in forum Client Support
    Last Post: 09-02-2010, 05:19
  2. Permissions Problems Using sudo to Run Server
    By Llewen in forum [TeamSpeak 2] Server Support
    Last Post: 12-06-2008, 16:21
  3. Problems
    By Another TS User in forum [TeamSpeak 2] Client Support
    Last Post: 07-12-2006, 15:21
  4. More problems with packet loss
    By aizauk in forum [TeamSpeak 2] Client Support
    Last Post: 08-10-2004, 07:44
