Results 1 to 15 of 26
Thread: Push to talk problem
07-01-2010, 08:03 #1
-= TeamSpeak User =-
- Jan 2010
- Location
- sydney aus
- 2
my voice acctivation works perfectly but push to talk dosnt.when im in setting/options/capture i pick push to talk when it asks for a hot key it just frezzes up and i have to shut down TS3 to get out of that screen.can someon please help!!!
07-01-2010, 14:43 #2
-= TeamSpeak Team =-
- Jun 2008
- 7,763
Give use some information about your hardware and operation system.
And TS3 client (32Bit/64Bit) information.
We are on it.
09-01-2010, 17:55 #3
- Dec 2009
- Location
- germany
- 13
my frend has the same problem
win xp
09-01-2010, 19:01 #4
- Dec 2009
- Location
- Italy
- 22
check your joystick!!!
if you'va a joystick try to load a profile and then setting/options/capture/PTT
10-01-2010, 17:13 #5
- Jan 2010
- Location
- USA
- 1
Same problem
Win xp 64 bit / SB X Fi Audio / Logitech G35 headset / TS3 64bit / Microsoft Natural Multy Media keyboard
Everything seems to work fine but I cant set a key to activate mic and I cant get out of activate key mode once in it.
I have to ctrl alt delete to bring up task manager to shut it down tried several times with the same results.
Not sure if its not recognizing the keyboard but in task manager it dosnt look like its not responding or locked up it just seems not to be getting a responce from the keyboard.
11-01-2010, 14:11 #6
- Jan 2010
- Location
- Germany
- 1
Hotkey Problem (They are not Working)
Hey guys!
I got the following problem:
I have set Hotkeys for Toggle Microphone and Push-to-Talk.
If I only run Windows everything works fine, but if i'm going to Start something in FullScreenMode, like Games, it's not working anymore. With TS2 everything worked fine before, and i would like to speak like everyone else during gaming.
There's a possibility to change that? I hope so
14-01-2010, 19:55 #7
- Jan 2010
- Location
- United States
- 8
Maybe try running the game or TS3 in compatibility mode.
Try a different key.
Is the TS3 the right version for you computer (32 bit / 64 bit)?
23-01-2010, 14:00 #8
- Dec 2009
- Location
- Germany
- 10
PPT does not work
hi,
like the title says, my ptt doesn't work. i can set a hotkey and when i press it, the light changes but no1 can hear me. even when i test my voice in the prefs it doesn't work. i have to change to voice activation and everything is OK. i tried to reinstall the app. i even tried lower betas but nothing worked.
can somebody help?
aaaxxxLast edited by aaaxxx; 23-01-2010 at 15:44.
25-01-2010, 04:45 #9
- Jan 2010
- Location
- melb.au
- 2
i am having the exact same issue, and it only seemed to happen since i upgraded from TS3x64-beta11 to beta 12.. its currently set to ctrl and i cannot change it now and have to end the process and just use voice activated.
im running windows7x64, ts3x64-beta12, onboard realtek soundcard, using MS vx3000 webcam for mic.
i will try downgrade back to beta11 and report back.
25-01-2010, 04:48 #10
- Jan 2010
- Location
- melb.au
- 2
same problem with beta11 now. and the
"press hotkey combination.
(ESC to cancell or to clear the hotkey)
box is always on top. so yeh. fubar
25-01-2010, 07:39 #11
-= TeamSpeak Addict =-
- Dec 2009
- Location
- Switzerland
- 444
The box can be closed with Alt+F4, but of course this is no solution.
25-01-2010, 21:45 #12
- Jan 2010
- Location
- California
- 1
I too can't get my ptt to work. I thought everything was fine when I set it up, but it won't work. However, my voice activation doesn't work either! Don't know if there is an issue with only running 10.4 and not the most current OS.
28-01-2010, 14:22 #13
- Dec 2009
- Location
- Germany
- 10
Well, I had the problem the other way around. The reason was the server and not the client who forced me to push to talk instead of voice activation. I suggest to test a different server first and if it's working fine, ask your server admin to check the settings.
29-01-2010, 13:15 #14
- Dec 2009
- Location
- Germany
- 10
its my own server.. and i am the only one having that kind of problem...
29-01-2010, 18:14 #15
- Jan 2010
- Location
- USA
- 3
PTT - doesn't recognize keyboard input
Suddenly... after using TS3 beta 12 for about 48hours (give or take), I can no longer set my PTT key.
The wizard will display either the GREY BOX or a SOLID BLACK BOX.
There is no sign of activity when I press the LEFT CTRL KEY... which is how I had previously set it up to work.
The wizard locks up completely. Clicking (with the mouse) in the GRAY BOX makes no sound. Clicking outside of the GRAY BOX makes the default Windows sound... as though you had scrolled to the top or bottom of a page.
The only way out is to three-finger SALUTE the PC and shut down the APP from within Task Manager.
TS3 is still running - whatever resident component - because I can see up to 3% CPU demand every once in a while in "Processes".
Is there NO fix for this?
Keith
vista and push to talk
By juuni in forum [TeamSpeak 2] Client SupportReplies: 5Last Post: 02-02-2009, 23:37 -
Push to Talk is not working
By cotner in forum [TeamSpeak 2] Client SupportReplies: 19Last Post: 05-11-2005, 17:27 -
Push to talk state will not change during certain activities
By Kilroy in forum [TeamSpeak 2] Client SupportReplies: 5Last Post: 27-07-2005, 02:20 -
Teamspeak and EQII problems with Push to Talk
By Umav in forum [TeamSpeak 2] Client SupportReplies: 0Last Post: 03-07-2005, 15:28 -
Push to NOT talk
By MrBonus in forum [TeamSpeak 2] General QuestionsReplies: 9Last Post: 21-06-2004, 08:48
