Results 1 to 10 of 10
    Jan 2010
    Hameln
    Cool Restart / attitudinal problem (Restart/ einstellungs Problem)
    So I basically 2 problems: D
    To prehistory I have a 64-bit server 3.0.0-beta12 with currently 2 Viretuellen servers run on.
    I've started to get almost everything eigendlich easily administered, and increased to the 512 license. Only the establishment must be noticed that a few little things.
    The first is that the server was reset again for some reason, max of 40 clients to 30. But since I have given me no other than SA and nobody else can because it is already something ran merkwüdig. The eigendlich worse problem or what I do not understand is this has become one of the two virtual servers REBOOT yesterday night while the other continues running as if nothing had happened.
    I have here in the forum a bit but unfortunately gestöbert found anything suitable. Perhaps someone has the problem also had schonmal or knows whether the nen bug or just a state of mind? Yes Is everything still beta and so ^ ^
    So now because English is now the 3rd mal was removed and it is still a bottomless pit. I am saving myself any further comment on these concerns intolerance what German language
    *** german part deleted *** > don't ignore the rules!
    Dec 2009
    Switzerland
    444
    Could you reproduce the problem where the max clients got reset? Perhaps you set it to the wrong value by accident because 30 is not even the default value.
    Do you have more information about the server restart? Was there an error in the log?
    And please do us one favor: If you are using Google Translate try to write correct German including correct punctuation. Otherwise the Google English is just gibberish.
    Jan 2010
    Hameln
    It came just as speech "server Edited" and "Channel has edited" problem is I was not himself present it can therefore only partially understand. When and why did not the likes eingestelten 40th But I have a 512 license. The funny thing is the one Viretuelle server has rebooted the other continued to run as usual. 2 empty folders in the log files and none of them has to be the timestamp of the evening has restarted where viretuelle. I can try with the German - English's problem ^ ^
    Dec 2009
    Switzerland
    444
    So someone else heard "Server edited", but you were not present? If it's not a recurring problem I would ignore it. Just double check you didn't give someone else admin permissions and change the serveradmin password if you think someone could have get their hands on it.
    And, please use shorter sentences. And really make sure the commas are at the correct position and there is no spelling error. Try using Word to fix the spelling Google Translate cannot produce readable English if the input language is already wrong.
    Jan 2010
    Hameln
    The users with less is not so important what surprised me more is the restart and no log
    Problem in English
    Jun 2008
    7,764
    Please check your logs for crash restart or something
    Jan 2010
    Hameln
    Then let me show you where the rules once it's German is not allowed
    The logs in order TS3 registers, I should look at, includes 2 empty log files.
    can say yes times exactly where I find these logs
    Jun 2008
    7,764
    Jan 2010
    Hameln
    2010-01-10 01:42:02.926425|INFO |VirtualServer | 1| stopped
    2010-01-10 01:42:11.080072|INFO |VirtualServer | 1| listening on 0.0.0.0:9987
    2010-01-10 01:42:11.081152|INFO |VirtualSvrMgr | | startServer() VirtualServer(1) started
    2010-01-10 01:49:31.749141|INFO |VirtualServer | 1| stopped
    2010-01-10 01:49:44.570984|INFO |VirtualServer | 1| listening on 0.0.0.0:9987
    2010-01-10 01:49:44.572012|INFO |VirtualSvrMgr | | startServer() VirtualServer(1) started
    Jun 2008
    7,764
    Seems, that someone or some group has permission to stop/start the server.
    This is my log. Please check permissions
    2010-01-15 15:32:31.946913|INFO |VirtualServer | 1| stopped
    2010-01-15 15:32:40.540405|INFO |VirtualServer | 1| listening on 0.0.0.0:9987
    2010-01-15 15:32:40.541405|INFO |VirtualSvrMgr | | startServer() VirtualServer(1) started
  1. Server Restart, UDP problem
    By stringseagle in forum [TeamSpeak 2] Server Support
    Last Post: 24-08-2009, 17:55
  2. Server Restart Problem
    By New 2 Linux in forum [TeamSpeak 2] Server Support
    Last Post: 20-12-2004, 06:57
  3. PC Restart problem...
    By Fass in forum [TeamSpeak 2] Client Support
    Last Post: 04-03-2004, 06:34
