Page 2 of 5 FirstFirst 1234 ... LastLast
Results 16 to 30 of 71
  1. #16
    Jan 2010
    Poland
    9
    I'm curious and sometimes it conflicts with hotkeys in games.
    So it's nothing important really (or nothing I couldn't change in game anyway).
    Hmm, and somehow Foobar stopped responding to muting hotkeys sent by plugin :S
    EDIT: I can press CTRL+ALT+NUM1 myself and it works...
  2. #17
    Jan 2010
    localhost
    40
    Ah, this bug I had a long time ago but I couldn't reproduce it :/
    I'm working on a solution without using hotkeys which will be much more stable
    Chris
  3. #18
    Jan 2010
    Poland
    9
    I just reproduced the bug on hotkeys resuming playback:
    1. Tried to enter invalid key hex value (so the message was: [foolower] Hotkey for resume is now CONTROL + ALT + 0x0).
    2. Entered 63 as hex key value (so the message was: [foolower] Hotkey for resume is now CONTROL + ALT + 0x63).
    3. Resuming playback doesn't work from plugin (manually pressing hotkeys does work).
  4. #19
    Jan 2010
    localhost
    40
    You know that 0x63 (NUMPAD1) is mute, and not resume, by default?
    Chris
  5. #20
    Jan 2010
    Poland
    9
    According to the list linked in /foolower help (http://msdn.microsoft.com/en-us/libr...loband%29.aspx) 0x61 is NUM1 and 0x63 is NUM3.
    Nevertheless it doesn't work even if I change mute to 0x63.
  6. #21
    Jan 2010
    localhost
    40
    Ok. Now I know what exactly you mean, sorry for my misunderstanding. I've same problem, now looking what causes this.
    Thanks for reporting!
    Chris
  7. #22
    Jan 2010
    localhost
    40
    Updated to 1.5, hotkeys can now be configured without problems (thanks to Woytaz).
    Chris
  8. #23
    Jan 2010
    Poland
    9
    Everything works fine now. Great job!
  9. #24
    Jan 2010
    localhost
    40
    Updated to 1.6, now comes with a second workaround without using hotkeys!
    Please read first post!
    Thanks,
    Chris
  10. #25
    Jan 2010
    germany
    thx for that addon !
    is it possible to add also an itunes suppord ?
  11. #26
    Jan 2010
    localhost
    40
    Yes, I already thought about that idea since with the volumes method winamp _should_ be supported automaticly (not tested and not official supported by me!).
    Next step is to come away from (yes, blame me) GetPrivateProfileInt and brothers, then I will eventually adding support for other systems.
    Chris
  12. #27
    Jan 2010
    Berlin
    Thumbs up
    yep, thx for the plugin - works fine @ xp 32 bit
    hope the 64 bit version will be rdy soon so my new pc can also use it...
  13. #28
    Jan 2010
    germany
    that should be really nice!
    i just try to search for an shortcut option for itunes in windows who i can adjust ctrl alt num1 for mute - but i dont find a solution...yet ;/
    sry for my bad english.
  14. #29
    Sep 2004
    The Netherlands
    Just got it running with winamp-foobar-plugin. Works perfectly, thanks!
  15. #30
    Dec 2009
    Germany / Hamburg
    Well, currently I'm planning to use the web control panel plugin of foobar2000 to workaround all this childsplay
    Will begin next weekend.
  1. [Resolved] [already possible] Hotkey sound volume control
    By SixOp_Alpha8 in forum Suggestions and Feedback
    Last Post: 19-01-2012, 12:26
  2. Replies: 8
    Last Post: 16-01-2010, 02:22
  3. tscontrol.exe volume control
    By jes1510 in forum [TeamSpeak 2] Addons & Scripts
    Last Post: 10-11-2006, 15:13
  4. Volume Control management
    By agrabren in forum [TeamSpeak 2] Addons & Scripts
    Last Post: 18-07-2005, 12:19
  5. mic not picking up anything
    By majom in forum [TeamSpeak 2] Client Support
    Last Post: 17-10-2004, 22:51
