Results 1 to 11 of 11
22-04-2003, 14:15 #1
-= TeamSpeak User =-
- Apr 2003
- Location
- Michigan
- 5
TS2 RC2 using CPU resources when inactive.....
Ok, here I go
While playing BF1942 I notice quite a bit "game lag" when team speak is running. My pings are fine, it is my FPS that are being hit. At first I thought it may have been a bandwidth issue, so I turned it all the way down to 17Kb(2.13KB) for both up and down.....this did not seem to work. So a friend thought it may have been compressing it too hard, so I set it back to unlimited...but then I turned down the 3step qualtiy meter to its lowest - this still didnt help. When closing out of TS2 when playing BF1942, everything is fine.
So, I decided to exit out of my game and close every program. I watched my CPU usage via coolmon for the next min....it consistantly jumped from 0-1%...the norm. Then I opened TS2 RC2...it now jumped the CPU from 6-19% the entire time....and this is not when in a server. I joined my friends server(1 other person logged into it) and I still was jumping the CPU from 6-19%.
I called up a buddy of mine that I play BF1942 with, had him try out his TS2 RC2 with coolmon....his CPU idled at 0-1%.....but he does have a 2.4Ghz compared to my 900mhz. I was going to reinstall last night, but the download section was down....so I'm posting here for now till I get home today.
My system specs:
Windows XP SP1 w/current hot fixes
AMD T-Bird 900
512MB PC133
Abit KT7-RAID mobo
Creative Live Drive w/Live 5.1 sound card w/latest Creative drivers
Visiontek GF4 Ti4600 128MB
DirextX 9.0
Cable 1.5/256
Friends System specs:
Windows XP SP1 (no hot fixes since SP1)
Intel P4 2.4 Northwood
512 DDR 2700
MSI 845PE
Creative LIve Drive w/Live 5.1 sound card w/latest Creative drivers
ATI 8500DV
DirectX 9.0a
DSl 1.5/256
We both downloaded TS2 RC2 the same day. I know his PC may be running it better since he is twice as fast, but he is the only person I can really compare too right now.
Any ideas?
FYI - I did see the codec thread in the FAQ forum and may try that if no one else has any ideas.Last edited by mtmra70; 22-04-2003 at 15:55.
22-04-2003, 14:25 #2
- Apr 2003
- Location
- Michigan
- 5
mabye as a 'half-ass' solution, could I run TS1 or a "lite" version of TS? All I need it to do is transmit my voice and receive my voice....I do not need all the features of TS2.
22-04-2003, 15:22 #3
-= TeamSpeak Guru =-
- Aug 2002
- Location
- Switzerland
- 8,182
are you using the HW Sound acceleration of BF1942 ?
Several threads do recommand to turn this off.
22-04-2003, 15:24 #4
- Apr 2003
- Location
- Michigan
- 5
I am but I found that BF1942 plays better with it on.
This would not resolve the CPU spikes when the only program open is TS2.
23-04-2003, 12:57 #5
- Apr 2003
- Location
- Michigan
- 5
Update:
reinstalled fresh TS2 RC2 download, still getting 6-19% CPU usage when sitting idle.
28-04-2003, 19:20 #6
- Apr 2003
- Location
- Michigan
- 5
anyone??????????
28-04-2003, 21:43 #7
-= TeamSpeak Support =-
- Oct 2002
- Location
- Germany
- 2,594
sorry, my TS takes absolutely 0 % of my cpu usage to sometimes 6 %. (Athlon 1,4 GHz, 256 mb ddr, asus via)
cu
SatanClaus
28-05-2004, 16:03 #8
- May 2004
- Location
- home
- 19
Your issue is your 900 mhz cpu..need something faster if you want to reduce your cpu usage under ts2...
05-09-2004, 02:38 #9
- Sep 2004
- Location
- USA
- 4
i have the same damn problem and i have an very fast pc
Windows XP SP2
Intel P4 2.0 Northwood
1GB DDR 3200
Gigabyte 8lPE1000 Pro
AC'97 sound card w/latest drivers
Nvida 5200
DirectX 9.0C
DSl 1.5/256Last edited by johnson486; 05-09-2004 at 05:12.
05-09-2004, 05:11 #10
- Sep 2004
- Location
- USA
- 4
well it's taking any where from 15% to 25% of cpu useage when i'm talking an any where from 10%-15% when not useing it
05-09-2004, 12:12 #11
- Aug 2002
- Location
- Switzerland
- 8,182
AMD 1900XP, SB Audigy, 768 DDR2700, DirectX 9.0b, win2k:
TS client (32.60) using from 0 - 2 % CPU time when not talking and a max of about 8 - 9 % when talking (usually 4 - 5 % when talking). Indenpendant of selected Codec and WAVE / Direct Sound in TS.
- I suspect your onboard soundchip (driver update, test a seperate SoundCard,...)
@mtmra70
A 900 MHz CPU for BF1942 ? That must be a joke ? Can't really imagine this
TS2 Problem / Cpu Auslastung bei 100%
By Fox One in forum [TeamSpeak 2] Client SupportReplies: 6Last Post: 21-10-2005, 17:26 -
need help to get TS2 RC2 started
By sinister nation in forum [TeamSpeak 2] Client SupportReplies: 3Last Post: 30-03-2005, 14:10 -
Kann ts2 nicht starten.
By doedalu in forum [TeamSpeak 2] Server SupportReplies: 13Last Post: 22-05-2004, 05:52 -
Text Output from TS2 RC2 for Debugging
By Sorites in forum [TeamSpeak 2] Addons & ScriptsReplies: 0Last Post: 03-06-2003, 20:41 -
TS2 RC2 mit Router?
By denz` in forum [TeamSpeak 2] Client SupportReplies: 8Last Post: 08-04-2003, 18:07
