Results 1 to 7 of 7
05-02-2010, 04:55 #1
-= TeamSpeak User =-
- Feb 2010
- Location
- Virginia, US
- 3
[Solved] My talking lowers others volume
I have looked around and not seen this problem yet. I am on Windows 7 (64-bit) and when I talk on TeamSpeak3, if others are talking at the same time it will lower their volume in my headset. Basically while I am talking, I can no longer hear others until I stop, then they go back to normal volume.
Is this a known issue, and/or has it been solved? Would really like to fix this because it's really annoying.
05-02-2010, 06:10 #2
-= TeamSpeak Fanatic =-
- Nov 2008
- Location
- United States
- 1,791
take off priority speakers
05-02-2010, 13:21 #3
If you are not a priority speaker in the channel, look in your capture options (Settings, options, capture) and make sure "Echo reduction" is not selected.
06-02-2010, 03:45 #4
- Feb 2010
- Location
- Virginia, US
- 3
Nobody has Priority Speaker (including myself); and Echo Reduction was turned off and still the same problem remains. > <
[Edit: I should note, also, that I am the Operator of the server, perhaps it's in Server Group somewhere? Trying to find that out.]Last edited by royalflushxx; 06-02-2010 at 04:39.
06-02-2010, 06:55 #5
- Nov 2008
- Location
- United States
- 1,791
What's your sound card? I have a feeling that you have some setting (accidently, or purposely) that's contributing. This is only happening to you correct? No1 else on your server has this problem?
06-02-2010, 07:24 #6
- Dec 2009
- Location
- Europe
- 7
Hey Royal,
the problem has been posted and different solutions werwe suggested - but I cannot remember where I found it ^^.
What worked fopr me was, to go to SETTINGS - OPTIONS - RECORDINGS and reduce ECHO REDUCTIONS down to 0 (ZERO) db.
Then close TS3 and restart. That worked for me.
Good luck...
PS: Sorry if how to get to the ECHO feature is not 100% correct - I use ze german interface ^^
08-02-2010, 23:09 #7
- Feb 2010
- Location
- Virginia, US
- 3
Thank you very much, Jedimaus. This worked almost entirely for me! There's still a little bit of reduction in others' volume, but barely enough to notice.
All is good again.
[RELEASE] foolower - foobar2000 volume control
By rossmann in forum PluginsReplies: 70Last Post: 17-02-2013, 14:26 -
[Solved] Disabling auto volume leveling in a channel?
By Dragonshadow in forum General QuestionsReplies: 2Last Post: 19-01-2010, 19:54 -
[Solved] [REQUEST] Foobar2000 Volume control.
By jo0man in forum PluginsReplies: 8Last Post: 16-01-2010, 02:22 -
Volume Control management
By agrabren in forum [TeamSpeak 2] Addons & ScriptsReplies: 2Last Post: 18-07-2005, 12:19
