Results 1 to 5 of 5
Thread: [Solved] Default group setting
10-02-2010, 05:12 #1
-= TeamSpeak User =-
- Feb 2010
- Location
- Canada
- 5
Hey,
So with my TS3 server I've set up, I've had a problem with everyone being given Admin if they're not on any list yet. For example, when I go into permissions > server groups > server admin it says on the right side bar where the names are supposed to go: "Clients which are not in any other group are inside this group". Clearly the default group should be guest and NOT server admin. So the question is, how do I go about changing that?
Thanks
10-02-2010, 06:43 #2
-= TeamSpeak Team =-
- Jun 2002
- Location
- Krün / Germany
- 1,965
if you setup your server, fresh, the default group should be the guest group and not the serveradmin group.
are you sure someone dont changed that?
10-02-2010, 07:06 #3
- Feb 2010
- Location
- Canada
- 5
I have purchased the server through the company that I rent my gaming servers from - are you sure there is no other way than to completely re-do it?
10-02-2010, 07:31 #4
- Jun 2002
- Location
- Krün / Germany
- 1,965
- connect to your server
- ctrl + alt + e / alternativ open server edit dialog
- press more
- press tab misc
- Server Group: select "guest" group
- press apply
10-02-2010, 08:32 #5
- Feb 2010
- Location
- Canada
- 5
Awesome! Works
Thank you very much!
Now this is a completely different topic, but how can I edit the allowed idle time?
How to Install TS & MySQL 4 Properly
By DOMINATION in forum [TeamSpeak 2] Server SupportReplies: 242Last Post: 15-09-2009, 01:24 -
PHPNuke/Teamspeak?
By Tearlow in forum [TeamSpeak 2] Addons & ScriptsReplies: 4Last Post: 25-01-2009, 23:10 -
Probleme beim Installieren (mit MySQL) ? HOWTO und Erfahrungsbericht...
By Hector666 in forum [TeamSpeak 2] Server SupportReplies: 4Last Post: 18-05-2006, 12:27 -
Why dosn't this work...?
By Tearlow in forum [TeamSpeak 2] Server SupportReplies: 1Last Post: 02-11-2005, 22:23
