Results 1 to 15 of 15
    Feb 2010
    NZ
    14
    Question Cant connect using WAN IP
    Hi. Have had my server for a few days now. Problem is no one can connect to it using my external IP address (WAN IP) or my internal IP.
    I myself cannot connect using my own external IP address. Only way I can connect is if I use my IP4V address (internal IP) or the loopback IP 127.0.01.
    Any suggestions on fixing?
    I use Vista 32bit. I have forwarded the ports 8767 udp port,9987 UDP, 10011 TCP, 3033 TCP
    to both my firewall and my router.
    My router model is dynalink rta1025w.
    Any help would be appreciated. Clan members are complaining that its not working...
    Nov 2008
    United States
    1,791
    right click > run as admin
    Feb 2010
    NZ
    14
    Unhappy
    Have tried that. I clicked run as admin on both client TS and server TS and still the same problem..
    Nov 2008
    United States
    1,791
    did you forward the ports correctly? To the correct IP?
    You will only be able to connect to your own server by your LAN. You can't by using a WAN. So this is fine.
    Feb 2010
    NZ
    14
    Ok...well if it is fine...then the next problem is that my friends cannot connect using my external IP (the one i get from sites like ipchicken.com). So now that Im fixed I need to get my friends on as well. I have given them both my internal and external IP to try but still they cannot connect.
    Nov 2008
    United States
    1,791
    Can you take a picture of your forward ports?
    Feb 2010
    NZ
    14
    I tried but Im not sure if it worked. So should be below...
    Dec 2009
    Texas
    754
    1. no one will ever be able to connect using your internal ip. you don't need to give it out.
    2. you don't need the tcp ports only udp ports: 9987, 30033, and 10011
    check to make sure you are forwarding to your computer's ip address because it's probably dynamic.
    also please don't grey out any information except maybe a mac address or external ip. the internal ip is important to us and not dangerous to give out
    Feb 2010
    NZ
    14
    I can easily remove the ports not needed. But not much time right now.
    Also the IP i forward to is my internal IP. But to connect to Teamseak, I use 192.168.1.2 (which is my IP4V address).
    Nov 2008
    United States
    1,791
    Windows firewall? This might be causing problems. Any other firewalls?
    Feb 2010
    NZ
    14
    Windows firewall I have allowed exceptions already for TS. And i even turned windows firewall off completely. But still nothing. I dont have any other prgrams or any virus protection etc.
    Dec 2009
    Texas
    754
    Quote Originally Posted by redeye03 View Post
    you need to forward to the address OF YOUR SERVER aka the ip u use to connect internally to teamspeak
    Feb 2010
    NZ
    14
    It works! But another question...because my IP4V address keeps changing (the one i log on with), does that mean i have to re-forward my ports everytime? Co it such a hassle...
    Dec 2009
    Texas
    754
    you could set it to a static ip or most routers support forwarding to your pc name so when your ip changes the port forward changes. kind of like dynamic dns
    Feb 2010
    NZ
    14
    Ah Great! That works also! Thanks very much for your help!
    Now how do I turn this post to a "solved" question?
  1. Replies: 2
    Last Post: 12-01-2010, 16:33
  2. Problem. Can't connect from WAN
    By Verndroid in forum [TeamSpeak 2] Server Support
    Last Post: 18-12-2009, 08:19
  3. Can Not Connect Using Quick Connect
    By jmunsters in forum [TeamSpeak 2] Server Support
    Last Post: 15-03-2006, 12:49
  4. I can connect w/ LAN, no one else can connect with WAN
    By scfross in forum [TeamSpeak 2] Server Support
    Last Post: 03-03-2005, 18:51
  5. people unable to connect on wan side
    By spie in forum [TeamSpeak 2] Server Support
    Last Post: 16-05-2004, 04:07
