Results 1 to 5 of 5
    Apr 2003
    BE
    Angry AUDIGY 2 & TS weird very (!) annoying problem!!!
    HEEEEEEEEEEEEEEEEEEELP??
    OK I got you attention?
    I'm having a very problem with my TS config @ home. The reason why i post this is because i know for 100% that there is a sollution for my problem. We once solved the problem ourselves but I forgot how we fixed it now after a clean format i'm having the same problem again....
    ALL sound which my computer produces is directed to my microphone channel. Which means the green led next to my name lights up when I for example play a mp3 with my winamp. Which is VERY annoying for my friends who are in the same channel of TS.
    When I turn voice activation off and turn key activation on, the problem is solved... But activation with a key is way too complicated for me. Last week before my format I was using TS with voice activation and without that weird problem i'm having now. Which means THERE IS a solution for my problem. Only i forgot which one
    Please help me out...
    DrPepper (who is getting desperate)
    Feb 2003
    Denmark
    31
    try to lower your output level (bar goes to the left) ihave mine at 1/3 from the left. on another note u nmight wanna get used to oush to talk as this is most common in most games as people dont want to hear what goes on in your house
    and u dont want people to hear hehe trust me
    Oct 2002
    2,594
    I think your problem exist because your recording device is switched to "What u hear". So open your Creative Surroundmixer and switch the red-device to mic and to nothing else.
    Also you can mute your "yellow" mic slider afterwards, so you don't have to listen to yourself all the time.
    if this doesn't help, play around with the other options of your creative surround-mixer or any other mixer, like the standard windows-mixer.
    cu
    SatanClaus
    Apr 2003
    BE
    cu
    SatanClaus
    thnx!
    i'm @ work atm but tonight when i get home i'll give it a try
    Apr 2003
    BE
    cu
    SatanClaus
    problem solved
    SatanClaus Thank you VERY much! your solution worked superb!
    cheers
  1. Sound Problem with SB Audigy
    By KickThem in forum [TeamSpeak 2] Client Support
    Last Post: 26-10-2007, 00:01
  2. Hmm Annoying problem
    By Intense in forum [TeamSpeak 2] Client Support
    Last Post: 16-06-2007, 23:26
  3. Weird server problem
    By BlackKnight35 in forum [TeamSpeak 2] Server Support
    Last Post: 05-10-2004, 04:14
  4. Weird problem: plz help...
    By marine289 in forum [TeamSpeak 2] Client Support
    Last Post: 29-05-2003, 17:24
  5. WinXP Pro + Audigy Gamer problem?
    By Stinkfist in forum [TeamSpeak Classic] General Questions
    Last Post: 10-07-2002, 01:54
