Results 1 to 4 of 4
    Mar 2009
    76
    [Solved] i_group_*_power level issue
    In TS3 client permissions window for server groups i cannot set a higher i_group_*_power than 75 while all other i_*_power can be set to a higher value, eg. 105
    Mar 2009
    76
    For sure i cannot edit it because the default Server Admin Server Group has i_group_modify_power 75 and if i could set my level to a higher value the whole permissions system would be useless!
    As a super server admin (Server Query) i should be able to do that but i get:
    servergroupaddperm sgid=6 permid=17286 permvalue=105 permnegated=0 permskip=0
    error id=2569 msg=insufficient\sgroup\smodify\spower
    May 2006
    Europe/Czech Rep.
    1,299
    Quote Originally Posted by an3kk View Post
    addperm or edit?? !!
    btw you can give only as high as Grant permission allow you. So even if you are logged as serveradmin in serverQuery, your grant permissions are 100 nothing more.
    Mar 2009
    76
    Addperm.
    Yes, true, after writing the previous post i noticed that Query Admin has power level 100.
    Since i need 105 for Server Admin i modified the default.sql and set Query Admin to 200 and Server Admin to 105. Works very well. For sure i had to delete and create the one virtual server again (or i could have edited the database with sqliteman or such but was a test server).
    Issue solved!
  1. [Solved] Serious Sound issue
    By Barrybe in forum General Questions
    Last Post: 07-02-2010, 13:50
  2. [Solved] Reconnection issue
    By shadow_lmd in forum Client Support
    Last Post: 05-02-2010, 08:15
  3. Stealing nicknames
    By Freds in forum Permission System
    Last Post: 20-01-2010, 16:31
  4. [Solved] Permissions / Server Password issue
    By BobBart in forum Permission System
    Last Post: 14-01-2010, 19:28
  5. What is the security level for
    By Merlok in forum General Questions
    Last Post: 21-12-2009, 10:33
