Results 1 to 13 of 13
23-03-2010, 18:16 #1
-= TeamSpeak Fanatic =-
- Dec 2009
- Location
- Germany
- 1,382
[Tutorial] How to stream Sounds from System into TS
A little Tutorial "how to Stream Sounds" from your System -
into TS3 (other Software like TS2, Skype, etc. work with it too
** All Sounds = All what you hear from your PC (System Sounds, Music, Voices, etc.).
1.) Realtek SoundCard
1.1 -> Go in your Record Settings on your your System (where you set the Mic).
1.2 -> Make a right-klick in this Field
1.3 -> "Show deactivatet Devices"
1.4 -> Now you should see the Stereo Mix.
1.5 -> Aktivate it.
1.6 -> Use Stereo Mix as Record Device (TS, Skype, etc.).
1.7 -> Now all Sounds that you are hear listen Users in your Channel.
PS: If you don't see it, you need the Realtek HD Audio-Manager.
2.) VAC [Virtual Audio Cable] v4.10
2.1 -> Download VAC Chip Download (Or search an other per Google)..
2.2 -> Install it.
2.3 -> I would restart the System.
2.4 -> Set "Virtual Audio Cable 1" as outgoing Sound Device in your Player.
2.5 -> Set "Virtual Audio Cable 1" as Record Device (TS, Skype, etc.).
2.6 -> Now all Sounds that you are play in the Player listen Users in your Channel.
This work perfectly with the XP Mode under Win 7.
Btw: XP Mode is free, but run only on Win7!
Which Win7 you see on the Site (Link) :P
3.) SoundBlaster SoundCard
It's like the Same as Realtek, but with an other Name.
Link to an exactly Discription "How to enable What you hear" you would find here. (Thx to poisonpanik
Player Settings:
Foobar2000 (Screen)
Spider (Screen)
Winamp (Screen)
Windows Media (Screen)
Important:
If you want to stream Sounds/Music with Copyrights you need Licenses from GEMA & GVL.
Otherwise you could get many Problems.
Closing Words:
Enjoy and have Fun!
Last edited by SmokinShark; 07-07-2011 at 09:56. Reason: New VAC Version. (Win7 Support) / Player Settings Screens
30-03-2010, 13:53 #2
-= TeamSpeak Addict =-
- Nov 2009
- Location
- Dublin, Ireland
- 398
How to stream Sounds from system and talk at the same time:
Download VAC ( see above post )
In teamspeak go into Options > Capture
Create an additional Capture profile and call it something like " streaming "
In the streaming profile, select continuous transmission and select the device Virtual Audio Cable
Click connect, using the same identity rename yourself to something approrpiate ex. " streaming music " etc. Connect in a new tab
In the "streaming music" tab, click self > select capture profile > streaming
re-enable your microphone on your normal speaking tab and make sure the default capture profile is selected.
And now you can stream music through VAC, and talk at the same time or in a different channel.
09-07-2010, 13:57 #3
-= TeamSpeak User =-
- Jul 2010
- Location
- Austria
- 11
How can I get that "trail" away form VAC? every 20secs it says "TRAIL!" I can't stream with that noice.
I don't got Stereomix on my "Soundmax Integrated Digital HD Audio" Soundcard
09-07-2010, 14:07 #4
-= TeamSpeak Team =-
- Jun 2008
- 7,762
NPL License (Registration)
09-07-2010, 14:37 #5
- Jul 2010
- Location
- Austria
- 11
oh, wow! I didn't knew that!
omg! I dont pay 30€ for that!
Is there another way?
09-07-2010, 21:28 #6
- Dec 2009
- Location
- Germany
- 1,382
06-08-2010, 09:07 #7
- Jan 2010
- Location
- Indiana
- 9
Creative cards have that feature disabled for Vista and 7, unless you buy their premium cards. And VAC doesn't work on 7 x64. As well, paying 30eu to stream music through a voice chat is a massive waste of money on a scale of epic proportions. (specially when it just plain doesn't work)
Seems a large group of users are left out of all the fun.
07-08-2010, 11:38 #8
- Dec 2009
- Location
- Germany
- 1,382
Enable it? ...
& VAC work on 64 Bit!
--- Merged ---
Added (see #1 Post):
Tested Players with VAC.
If you want that i test more and post it there tell me your favorite Player if it it'snt in the List.
--- Merged ---
You don't know where you can find the Setting of your Player?
Watch this:
It's also postet in Post #1 to be up-to-date.
Your Player is'nt in the List?
Tell me which Player you Use to make a Screen for it too.
15-07-2011, 08:41 #9
- May 2010
- Location
- Moscow
- 1
Or just WIRE from audio out to audio in.
Is a best solution.
I stream from weak mashine to four servers, and VAC or audio mixer eats too many CPU speed. Why? Dont know.
Think standart! Use wire!
18-07-2011, 14:50 #10
- Dec 2009
- Location
- Germany
- 1,382
So, your PC is to bad.
My CPU is on max 11% when i stream.
A wire sucks, because the Energize Variations.
03-10-2012, 00:01 #11
For Mac
there is a way,
FREE
i use SoundFlower Audio in/out-put core audio, just Like "Virtual Audio Cable"
And
($32)
Audio HiJack Pro:
Send direct audio, and Stream any Audio App, and Control The audio the way u wana hear it,(EQ Reverb)
even i muted Bass 20Hz - 50 Hz -20Dbs(Off) for TS3, (i dont need to hear "deep voice bass")
07-10-2012, 18:54 #12
- Sep 2012
- 2
Music bot
can someone help me (tell me all the steps) into getting a Music Bot for my teamspeak server? like where it just sits in a channel constantly playing music. i seen it in a few different teamspeaks and i wanna get one for my own
-----------merged-----------
bump because no one posted but 97 views
help needed.
This whole thread was moved. Please use the search function first.Last edited by dante696; 15-10-2012 at 12:47.
11-10-2012, 06:27 #13
-= TeamSpeak Lover =-
- Jun 2011
- 47
its alot of effort to commit that could be easily found.
That being said ill give you the low down. With hope that you are remotely computer savvy.
Simply you have a second client running a plugin.
You make it so this client can activate with very little sound.
Also make it so it doesnt hear anything by turning down incoming sounds completely.
If you dont want to dedicate the computer (is wise unless you have a very good computer that mostly does nothing) then you would use virtual sound tunneling software to essentially emulate a soundcard. so it doesn't get effected by any normal sound. (This is VERY CPU demanding)
If you do have a dedicated comp then you simply mute sound and set recording device to the mixer. This is required to make what you hear go through the mic.
The bot can use multiple software to do things. VLC is the best for youtube. (if you run on the same computer have a separate install thats configed for your emulated soundcard.
If you want to listen to a stream then use Winamp. (again make sure you config it. Which im not 100% if you can change its output device)
While some things are vague that is up to you to simply find the addon in the addon section and go to the link. (hard right?)
If you have a problem trying to use it THEN please ask away.
[DEV] Ts3 Webinterface
By Psychokiller in forum ToolsReplies: 784Last Post: 16-05-2013, 03:47 -
please help someone
By theundead67 in forum [TeamSpeak 2] Server SupportReplies: 59Last Post: 31-03-2007, 04:53 -
Error, Either an old instance of teamspeak is still running, or an other appl
By ||Gecko|| in forum [TeamSpeak 2] Server SupportReplies: 6Last Post: 18-06-2006, 12:04 -
Ich habe ein IP problem
By Filzl@us in forum [TeamSpeak 2] Server SupportReplies: 11Last Post: 05-12-2004, 16:09 -
Fehlermeldung beim oeffnen von ts
By ahempi in forum [TeamSpeak 2] Server SupportReplies: 9Last Post: 30-10-2004, 16:29
