Results 1 to 9 of 9
02-06-2010, 16:19 #1
-= TeamSpeak User =-
- Mar 2010
- Location
- Germany
- 2
[Suggestion] General Filebrowser for Admins
would it be possible to add an options in the permissions systems which allows Admins or any Person to simply view all files uploaded on a server by opening the filebrowser via right clicking on the virtual server name (sth. like the "edit virtual server thing").
This would make it a lot easier for:
1. Admins to find and delete unauthorized files or illegal stuff
2. Users to find and download files faster.
Just my two cents to the file system =).
MfG Silthus
02-06-2010, 16:29 #2
-= TeamSpeak Fanatic =-
- Feb 2006
- Location
- Texas, USA
- 4,187
The filebrowser is attached to a specific channel. You can already set the permissions so that anyone can view the filebrowser.
02-06-2010, 16:34 #3
- Mar 2010
- Location
- Germany
- 2
That's not what I meant...
I am looking for an option to list all files on one virtual server with one click instead of looking in every channel if there is a file uploaded there or not.
MfG Silthus
02-06-2010, 16:36 #4
- Feb 2006
- Location
- Texas, USA
- 4,187
Simple solution to this is allow only 1 channel to have a file browser
02-06-2010, 16:52 #5
- Jun 2010
- Location
- Germany
- 2
Noooo,
silthus wants to say, that there should be the permission "view all files uploaded on the server".
Admins have to control their servers to avoid illegal avtivities like up and downloading music tracks with copyright.
For example you have a server with 60 channels it is much easier and more comfortable to view all files with a single mouseclick.
02-06-2010, 21:45 #6
- Jan 2010
- Location
- Secret Base in Arctic Region
- 1,187
As said, control who you give permission to up/download.
And dont set file transfer permissions for every channel, it to much work.
10-06-2010, 10:55 #7
-= TeamSpeak Addict =-
- Dec 2009
- Location
- Germany
- 231
I check it from time to time using find:
But surely not every serveradmin has access to the server. If you running your own server, chances are good you have a webserver running as well. Then you could export the files directory password protected. Or use php to show the file list created by find...Code:find -type f /opt/teamspeak3-server_linux-x86/files/virtualserver_1/
All only workarounds, but I hope it helps.
10-06-2010, 11:08 #8
-= TeamSpeak Guru =-
- May 2010
- 6,372
I have a old php script as an TS viewer but folder version for all channels on server.
If anybody is interested, i'll try to find it
18-02-2011, 00:16 #9
-= TeamSpeak Lover =-
- Feb 2010
- Location
- brazil
- 48
[Sugestion] File Browser Tree
it would be nice to have something like that, so you can browse the files from each channel w/o needing to open the file browser every time you wanna check if that channel have or not any files, this could even have a function to show all the files in the whole server at once, and maybe just show up the path as a description.
