Results 1 to 3 of 3
    May 2010
    40
    Exclamation Difference between i_ and b_ ?
    What is the diffrence between "i_" and "b_" ? Is there an importance?
    Feb 2006
    Texas, USA
    4,187
    a B permission is a true/false and an I permission requires a number (integer)
    Jan 2010
    Secret Base in Arctic Region
    1,202
    The Prof should read the documentation of TS (if available).
    What kind or permissions are there?
    Boolean Permissions
    These permissions can only have two values, true or false.
    Example:
    b_virtualserver_modify_name
    From the name of the permission you immediately see that it a boolean permission, since it
    begins with "b_". After this prefix is the actual name of the permission, which should give
    you an idea what the permission is about. In this case the permission controls if you may
    change the virtual server name. If it is set to true, you can change the virtual server name,
    if it is set to false or not set at all you can not edit the virtual server name.
    Integer Permissions
    These permissions accept integers as values.
    Examples:
    i_channel_max_depth
    From the name again you can see that it is an integer permission, because it is prefixed with
    "i_". The actual name of the permission, channel_max_depth in this case tells you what this
    permission controls. In this case it controls how "deep" channel structures you may create. So
    if the value is set to "0", it means you can create only top-level channels. If it is set
    to "1", you can also create sub-channels. Set to "2" you can also create sub-sub-channels and so on.
    As with many permissions that have no logical limit i_channel_max_depth also has a special value of "-1"
    which means there is no maximum depth limitation for channels.
  1. Difference?
    By Omlet in forum Permission System
    Last Post: 26-03-2010, 16:49
  2. difference between 32 & 64 bit
    By klink in forum General Questions
    Last Post: 03-01-2010, 14:39
  3. How to allow guests to join without a server pw?
    By djnoob in forum Permission System
    Last Post: 25-12-2009, 04:19
  4. TS3 = New Codecs?
    By damutt13 in forum [TeamSpeak 2] General Questions
    Last Post: 06-10-2007, 15:37
  5. What's the difference?
    By rlynch437 in forum [TeamSpeak 2] Server Support
    Last Post: 26-09-2005, 13:51
