Results 1 to 5 of 5
    Jun 2010
    New Hampshire
    15
    Solved [Solved] Skin troubles Help Appreciated!
    I am currently making a skin for my clan. So far everything is going well and I am almost finished. However, there are a few areas that I cannot seem to figure out how to change.
    I am using the bluesky.qss as a template.
    http://i302.photobucket.com/albums/n...7/TS3Skin7.png
    As you can see from the screenshot, I have circled the areas I cannot find. The first, in the Options menu is that blue bar. what is the code to change that? That same bar can be found on the Manage/Add New Bookmarks menu.
    Also, I cannot find where to change the background of the Manage/Add New Bookmarks menu. What is the code for those?
    Any help would be greatly appreciated!
    Jun 2010
    New Hampshire
    15
    Quote Originally Posted by 82ndAB-RedHawk View Post
    After doing more searching, I have found that part, but I still cannot find where to get rid of that blue bar in the options menu.
    Jun 2010
    New Hampshire
    15
    Finally found where the blue bar is. If you remove this line of code:
    QMenu::item {
    background: transparent;
    padding: 3px;
    padding-left: 20px;
    padding-right: 10px;
    it removes the blue bar. However, it removes a ton of other things as well for some reason.
    I just want to change the color of the blue bar. I have tried changing the background color, but it didn't work.
    Jun 2010
    New Hampshire
    15
    Here are some screenshots of what happens when I delete the code:
    QMenu::item {
    padding: 3px;
    padding-left: 20px;
    Before:
    http://s302.photobucket.com/albums/n...=TS3Skin10.png
    After deletion:
    http://s302.photobucket.com/albums/n...=TS3Skin12.png
    Jun 2010
    New Hampshire
    15
    I have solved the problem.
    In the qss file, there are a couple lines:
    QLabel, QCheckBox, QRadioButton, QGroupBox, QSlider, QWidget#HeadlineLabel, QFrame#bookmarksTopFrame, QWidget#advancedWidget, QWidget#statusChangeWidget, QWidget#connectToWidget, QWidget#switchToWidget, QWidget#disableWidget, QWidget#activateWidget, QWidget#recordingWidget, ImprovedTabBarCloseButton, QWidget#avatarWidget, QWidget#ToolbarStretcher, QStackedWidget {
    background: none;
    What you need to do is delete QWidget#HeadlineLabel and QFrame#bookmarksTopFrame.
    Then you need to add this line of code:
    QWidget#HeadlineLabel {
    background: #424f42;
    QFrame#bookmarksTopFrame {
    This will change the color of that blue bar to a light olive green color.
  1. [Skin] PS1D3R Dark Skin
    By Sp1D3r in forum Skins
    Last Post: 26-05-2010, 01:17
  2. [Skin] Portal Skin
    Last Post: 26-05-2010, 01:14
  3. [Skin] DVDTS Skin (First TS3 Skin)
    By DvdRom in forum Skins
    Last Post: 02-05-2010, 21:52
  4. Anime Skin
    By hyprdmg in forum Skins
    Last Post: 27-01-2010, 23:41
  5. [Solved] Login troubles
    By efialt in forum Permission System
    Last Post: 18-01-2010, 11:12
