Page 1 of 40 12311 ... LastLast
Results 1 to 15 of 592
    Feb 2006
    Texas, USA
    4,187
    Post [Tutorial]Port Forwarding (a.k.a. clients cannot connect)
    Please don't PM me with a question or problem related to this topic unless you've first posted in this topic and are having trouble after receiving an answer to your post. Posting the question or problem in this thread is much better as someone else may have the same problem or question and if you PM me for the answer no one else reading this thread will know what the answer was to that question or problem.
    Here's a brief explanation on port forwarding for those that are having trouble getting clients to connect to their server.
    (Beta 25 - The black box that opens when you run your server is your server so don't close this!)
    First you need to know the ports TS3 is using. In the FAQs these ports are listed as follows:
    Default voice port (UDP): 9987
    Default filetransfer port (TCP): 30033
    Default serverquery port (TCP): 10011
    (this part for windows users only
    Next you need to know the IP address of the computer running the server. Go to the start menu and click RUN. Now type cmd. In this new window type ipconfig and find the IPv4 address. (see pic #1) This is your LAN IP address. You will forward the ports to this IP address. Anyone on your personal network will need to use this IP to connect to your server.
    (for all operating systems)
    Now go to http://whatismyip.com/ to find your external IP address. (see pic #2) This will appear in the top center of the page. Give this to your friends so they can connect.
    Go to http://portforward.com/ and find your router make and model. On the 2nd page select SKIP THIS ADVERTISEMENT in the top right then select Teamspeak on page 3.
    **NOTE** If you only have a modem or use a fiber optic internet connection You may have to consult your device's manual or contact your ISP for more information.
    Follow the instructions on this page but be sure to use the ports for Teamspeak 3 and not the Teamspeak 2 ports they have listed on this page. NOTE: Some routers require a port range and not just a single port. Example would be 9986-9988 to open port 9987.
    If this is done properly your ports will be forwarded through your firewall and your friends outside your LAN should be able to connect.
    Please don't PM me with a question or problem related to this topic unless you've first posted in this topic and are having trouble after receiving an answer to your post. Posting them in this thread is much better as someone else may have the same problem or question and if you PM me for the answer no one else reading this thread will know what the answer was to that question or problem.
ID:	3643   Click image for larger version.
    May 2010
    6,372
    Add information
    Good tuto.
    (The black box that opens when you run your server is your server so don't close this!)
    This will be not necessary from BETA 26
    Feb 2006
    Texas, USA
    4,187
    Great news! I'll be sure to edit this when 26 comes along. I knew the devs had said that would happen. Did they make it a system tray icon like TS2 was? Hope they brought back the right click->SHOW MY IP option like TS2 had
    May 2010
    6,372
    Yes we have an icon.
    But for this moment (when I write this post) with the right click we just have the exit button
    *** Add to Poisonpanik's Tuto ***
    To be sure that your server used the good IP (if your server machine have a several IP) and to be sure your port is good forwarded, you can used this site :
    http://www.canyouseeme.org
    Thank's Dante696
    Feb 2006
    Texas, USA
    4,187
    Maybe that'll be in a later release. Would be great if it said LAN IP = XXX , WAN (or external) IP = XXX I'll wait and see how it goes and if it doesn't show up in an update or two I'll toss the request out there.
    May 2010
    6,372
    Yes, and it's will be necessary with voip_ip, ftp_ip and query_ip parameters
    Aug 2010
    Denmark
    I opend all ports: but still can my friend not join, this massage shows: Failed to connect to server.
    Feb 2006
    Texas, USA
    4,187
    PM me your ip/port and I'll try to connect.
    I also get a failure. Do you have any software like anti-virus or firewall that might be preventing the connection?
    Aug 2010
    Denmark
    No i dont have ;(
    Aug 2010
    Victoria
    6
    Where do I find these instructions for Mac?
    Feb 2006
    Texas, USA
    4,187
    Here is how to find your LAN IP address on a Mac.
    http://www.wikihow.com/Find-Your-IP-Address-on-a-Mac
    Finding your external IP and the port forwarding should be the same.
    Aug 2010
    Victoria
    6
    I haven't been able to get this to work... Any other suggestions on finding the Ip address?
    Dec 2004
    RF
    1,693
    http://checkip.dyndns.com/
    Note that all these services rely on assumption that you don't have any intermediate proxy servers between your browser and the service site.
    You can try http://checker.samair.ru/ to test for proxy, but it's not 100% reliable, however. (i.e., it can't detect my proxy at all :P )
    Feb 2006
    Texas, USA
    4,187
    Which part did you not get to work? If you can't find your computer's IP address do a google search for how to do this. I am unfamiliar with Mac.
    Aug 2010
    Victoria
    6
    Ok.. I used that site and found my IP address... but still no one can connect... and ..
    I don't know what an intermediate proxy server is and/or how to go around it or through it or whatever...
    Google just gives me the same instructions over and over for what I have done... any other suggestions?
  1. Permit low-version clients to connect?
    By Polli in forum Permission System
    Last Post: 30-12-2009, 07:39
  2. Two Clients can't connect at the same time.
    By PGerringer in forum [TeamSpeak 2] Client Support
    Last Post: 29-01-2006, 01:30
  3. Another clients can't connect.
    By Veldrin in forum [TeamSpeak 2] Server Support
    Last Post: 06-10-2005, 03:32
  4. Why can some clients connect and others can't?
    By trmentry in forum [TeamSpeak 2] Server Support
    Last Post: 15-08-2005, 23:11
  5. ant suggestions on how to get clients to connect to my server
    By razorback in forum [TeamSpeak 2] Server Support
    Last Post: 22-03-2003, 09:47
