Results 1 to 15 of 55
10-04-2010, 14:07 #1
-= TeamSpeak Lover =-
- Dec 2009
- Location
- Localhost
- 30
Server 'crash', "detected incorrectly running system clock"
Hello!
My teamspeak server is on a MySQL database on a separate server when I was placed on the Teamspeak server database SQLite was not the problem just now started to happen so that the server then throws all the 3 seconds you can enter it again is very annoying. Below I've included a log of the server.
How do I fix this?2010-04-09 21:56:19.255568|INFO |VirtualServer | 1| query client disconnected 'TSViewer.com DBscan REG 915244'(id:323) reason 'reasonmsg=disconnecting'
2010-04-09 21:56:29.791031|INFO |VirtualServer | 1| client disconnected 'xxSlayeRxx'(id:669) reason 'reasonmsg=leaving'
2010-04-09 21:56:32.109854|INFO |VirtualServer | 1| client connected 'xxSlayeRxx'(id:669) from 194.146.218.83:1213
2010-04-09 21:56:34.672161|INFO |VirtualServer | 1| client disconnected 'Nivalis'(id:171) reason 'reasonmsg=connection lost'
2010-04-09 21:57:00.411943|INFO |VirtualServer | 1| client connected 'Nivalis'(id:171) from 213.241.66.57:3623
2010-04-09 21:57:11.013971|INFO |VirtualServer | 1| client disconnected 'xxSlayeRxx'(id:669) reason 'reasonmsg=leaving'
2010-04-09 21:57:12.801611|INFO |VirtualServer | 1| client connected 'xxSlayeRxx'(id:518) from 194.146.218.83:1213
2010-04-09 21:57:29.447663|INFO |VirtualServer | 1| client disconnected 'invidia'(id:663) reason 'reasonmsg=connection lost'
2010-04-09 21:58:19.637203|INFO |VirtualServer | 1| permission 'i_channel_join_power'(id:13683) was deleted by 'xxSlayeRxx'(id:518) from channel 'Mix 1'(id:65)
2010-04-09 21:58:20.284236|WARNING |PktHandler | | detected incorrectly running system clock
2010-04-09 21:58:20.332143|INFO |VirtualServer | 1| client disconnected 'xxSlayeRxx'(id:518) reason 'reasonmsg=connection lost'
2010-04-09 21:58:20.392223|WARNING |PktHandler | | detected incorrectly running system clock
2010-04-09 21:58:20.461169|INFO |VirtualServer | 1| client disconnected 'Yung'(id:405) reason 'reasonmsg=connection lost'
2010-04-09 21:58:20.574236|WARNING |PktHandler | | detected incorrectly running system clock
2010-04-09 21:58:20.628597|INFO |VirtualServer | 1| client disconnected 'Alarinius'(id:664) reason 'reasonmsg=connection lost'
2010-04-09 21:58:21.291720|WARNING |PktHandler | | detected incorrectly running system clock
2010-04-09 21:58:21.306531|INFO |VirtualServer | 1| client disconnected 'Gonsiorek'(id:394) reason 'reasonmsg=connection lost'
2010-04-09 21:58:21.391184|WARNING |PktHandler | | detected incorrectly running system clock
2010-04-09 21:58:21.812535|INFO |VirtualServer | 1| client connected 'xxSlayeRxx'(id:518) from 194.146.218.83:1213
2010-04-09 21:58:21.869582|INFO |VirtualServer | 1| client disconnected 'Serek'(id:349) reason 'reasonmsg=connection lost'
2010-04-09 21:58:21.931572|WARNING |PktHandler | | detected incorrectly running system clock
2010-04-09 21:58:21.991524|INFO |VirtualServer | 1| client disconnected 'Luna'(id:604) reason 'reasonmsg=connection lost'
2010-04-09 21:58:22.019663|WARNING |PktHandler | | detected incorrectly running system clock
2010-04-09 21:58:22.057851|ERROR |VirtualServer | 1| connectionLost() invalid clientID: 0
2010-04-09 21:58:22.107779|WARNING |PktHandler | | detected incorrectly running system clock
2010-04-09 21:58:22.147774|INFO |VirtualServer | 1| client disconnected 'HONESTY'(id:26) reason 'reasonmsg=connection lost'
2010-04-09 21:58:22.172878|WARNING |PktHandler | | detected incorrectly running system clockLast edited by meliorus; 11-04-2010 at 23:38.
10-04-2010, 16:05 #2
-= TeamSpeak Team =-
- Jul 2002
- Location
- Germany
- 2,836
Well, this happens when the system clock "jumps" around (skips into the future, or into the past). Why it is doing this I do not know, there are many possible causes...your hardware might be broken, or your might be running some not so clever scripts that fool around with the time. Where the database runs should have no impact on this issue.
You think my answer is stupid ? Read This:
http://www.catb.org/~esr/faqs/smart-...ons.html#intro
In a world without fences and walls - who needs windows and gates ?
11-04-2010, 23:22 #3
- Dec 2009
- Location
- Localhost
- 30
This is only one mistake which I leap at the opportunity with an error:
[QUOTE]| ERROR | VirtualServer | 1 | connectionLost () invalid clientID: 0
I am concerned about is that all users who are on my server is kicked and then again after 3 minutes may come.
My Client Log throws me this error:Please continue to help fix this problem2010-04-11 23:55:31.411328 Info Logging started, clientlib version: 3.0.0-beta18 [Build: 10609]
2010-04-11 23:55:32.646347 ClientUI Info TeamSpeak 3 client version: 3.0.0-beta18 [Build: 10609]
2010-04-11 23:55:32.646347 ClientUI Info Qt version: 4.6.2
2010-04-11 23:55:32.646347 ClientUI Info Using configuration location: C: / Users/Ziom/AppData/Roaming/TS3Client/ts3clientui_qt.conf
2010-04-11 23:55:33.118854 ClientUI Info Last update check you: N 11th April 2010 10:02:37
2010-04-11 23:55:39.647962 PreProSpeex Info Speex version: speex-1.2beta3
2010-04-11 23:59:28.942004 ClientUI Info updateClient (): clientID invalid
2010-04-12 00:09:25.283681 ClientUI Info updateClient (): invalid clientID
this is my ts3server.ini:
machine_id=
default_voice_port=9987
voice_ip=0.0.0.0
liscensepath=
filetransfer_port=30044
filetransfer_ip=0.0.0.0
query_port=12548
query_ip=0.0.0.0
dbplugin=ts3db_mysql
dbpluginparameter=ts3db_mysql.ini
dbsqlpath=sql/
dbsqlcreatepath=create_mysql/
logpath=logs
logquerycommands=1Last edited by meliorus; 11-04-2010 at 23:37.
18-06-2010, 13:33 #4
-= TeamSpeak User =-
- Jun 2010
- 6
Hey everyone
We've got same problem and did you found any solution how to fix this damn issue? We just lookin forward to fix this somehow and it would be nice if anyone already know whats wrong.
Code:2010-06-18 05:38:35 PktHandler Warning detected incorrectly running system clock
19-06-2010, 20:52 #5
-= TeamSpeak Fanatic =-
- Dec 2004
- Location
- RF
- 1,693
How you are managing your system clock?
If you just running ntpdate now and then to set correct time, make sure it is using time adjustment instead of time step.
23-06-2010, 13:13 #6
- Jul 2002
- Location
- Germany
- 2,836
"detected incorrectly running system clock" means we queried for the current time
once, got some value A, then later queried again, got B, but B signified an earlier
point in time than A, so in effect the clock warped into the past. On linux systems
we use "gettimeofday" to query the system clock, on windows we use
QueryPerformanceCounter.
If you or some script you use changes the system time on UNIX this error can come
up. For synchronizing your clock with a timeserver use ntpd and not ntpdate.
If you are sure neither you nor some script is messing with the time, or if you are
seeing this error on Windows there is some deeper problem at work.
For windows systems, microsoft itself has a paragraph about possible causes
for QueryPerformanceCounter to produce bad results, quoting msdn:
So, bugs in the bios (maybe try a bios upgrade helps) or the kernel, or the hardware itself that is used to provide the system time can all cause the system time to misbehave. When running in some kind of a virtual machine there is yet annother layer between teamspeak and the hardware providing the system time, which can add problems too.On a multiprocessor computer, it should not matter which processor is called. However, you can get different results on different processors due to bugs in the basic input/output system (BIOS) or the hardware abstraction layer (HAL).You think my answer is stupid ? Read This:
10-07-2010, 03:45 #7
-= TeamSpeak Addict =-
- Jan 2010
- Location
- New England USA / Marnbach, Weilheim i.OB, Germany
- 435
[Fixed?] Server 'crash', "detected incorrectly running system clock"
On my client, I received "Connection to server lost" so I continued on to check my connection, and realized that it was the server that had dropped everyone. In the log is what is posted below just before everyone lost their connection to the server.
What I had done last before the server went down, was unchecked the check box in the logs tab when editing virtual server so that the log wouldn't log 'ServerQuery'. Before, I had the logs logging everything that they could log, all check boxes were checked. After editing the virtual server to NOT log ServerQuery, the "detected incorrectly running system clock" appears in log, and all clients lost their connection.
Server Version: 3.0.0-beta26-pre [Build: 11624]
Probably not a bug, what what is |WARNING |PktHandler | | detected incorrectly running system clock and would it cause a server to drop all clients connections?
I have searched the forums and have seen other people get this similar warning. I just thought I would post it because it occurred only after editing the Virtual Server to not log ServerQuery and following it, the server went down and all clients lost their connection.
Code:2010-07-10 01:47:21.969278|INFO |VirtualServer | 1| server was edited by 'Gen.Skylab'(id:2) 2010-07-10 01:47:21.969812|WARNING |PktHandler | | detected incorrectly running system clock 2010-07-10 01:47:21.970712|WARNING |PktHandler | | detected incorrectly running system clock 2010-07-10 01:47:21.971253|WARNING |PktHandler | | detected incorrectly running system clock 2010-07-10 01:47:21.971796|WARNING |PktHandler | | detected incorrectly running system clock 2010-07-10 01:47:21.972228|WARNING |PktHandler | | detected incorrectly running system clock 2010-07-10 01:47:26.646284|WARNING |PktHandler | | detected incorrectly running system clock 2010-07-10 01:47:26.647181|WARNING |PktHandler | | detected incorrectly running system clock 2010-07-10 01:47:28.355656|WARNING |PktHandler | | detected incorrectly running system clock 2010-07-10 01:47:28.357166|WARNING |PktHandler | | detected incorrectly running system clock 2010-07-10 01:47:28.358320|WARNING |PktHandler | | detected incorrectly running system clock 2010-07-10 01:47:28.360028|WARNING |PktHandler | | detected incorrectly running system clock 2010-07-10 01:47:28.361758|WARNING |PktHandler | | detected incorrectly running system clock 2010-07-10 01:47:28.362850|WARNING |PktHandler | | detected incorrectly running system clock 2010-07-10 01:47:28.363306|WARNING |PktHandler | | detected incorrectly running system clock 2010-07-10 01:47:28.363838|WARNING |PktHandler | | detected incorrectly running system clock 2010-07-10 01:47:28.364419|WARNING |PktHandler | | detected incorrectly running system clock 2010-07-10 01:47:28.365023|WARNING |PktHandler | | detected incorrectly running system clock 2010-07-10 01:47:28.365468|WARNING |PktHandler | | detected incorrectly running system clock 2010-07-10 01:47:28.366103|WARNING |PktHandler | | detected incorrectly running system clock 2010-07-10 01:47:28.366604|WARNING |PktHandler | | detected incorrectly running system clock 2010-07-10 01:47:28.367133|WARNING |PktHandler | | detected incorrectly running system clock 2010-07-10 01:47:28.367732|WARNING |PktHandler | | detected incorrectly running system clock 2010-07-10 01:47:28.368279|WARNING |PktHandler | | detected incorrectly running system clock 2010-07-10 01:47:28.368813|WARNING |PktHandler | | detected incorrectly running system clock 2010-07-10 01:47:28.369585|WARNING |PktHandler | | detected incorrectly running system clock 2010-07-10 01:47:28.370169|WARNING |PktHandler | | detected incorrectly running system clock 2010-07-10 01:47:28.395744|WARNING |PktHandler | | detected incorrectly running system clock 2010-07-10 01:47:28.399787|WARNING |PktHandler | | detected incorrectly running system clock
30-07-2010, 09:36 #8
- Jun 2008
- 7,762
Please retry this, with the official beta 26 release. This crash should be fixed.
http://ftp.4players.de/pub/hosted/ts3/releases/beta-26/
The error won't dissapear, because your system clock sends something wrong.
30-07-2010, 10:21 #9
- Jan 2010
- Location
- 435
Already have servers updated to 11927 and so far this error has been fixed. I'll let you know if this crash occurs again, thanks!
05-08-2010, 02:01 #10
- Nov 2006
- Location
- USA
- 45
Its not fixed.. I never had this before but since updating the server build to the latest I am not getting this error in mass and then the server restarts.
I hope there is an answer for this...
05-08-2010, 02:03 #11
- Jan 2010
- Location
- 435
24-08-2010, 23:23 #12
- Dec 2009
- Location
- Iceland
- 14
I have the exact same issue just started today at 03:00 or so GMT and now the server process has crashed twice due to it. i have force synched the ntpdate and we will wait and see what happens.
edit.
Every time somone is added removed or changes server or channel group the process crashes, and throws the exact same error you guys are having.
edit
I have force synchronised the system clock using ntpd but the issue continues to happen. I have had no issues like this prior to beta 27 and nothing on the limux server has changed at all.Last edited by VPope; 25-08-2010 at 11:27.
21-09-2010, 01:47 #13
- May 2009
- Location
- London
- 16
I guess this problem is unresolved then?
03-10-2010, 13:23 #14
detected incorrectly running system clock (beta29)
I have updated to the new version Beta29 and now I have connection problems. All people leave the server and can reconnect in next 5 minutes. This problem occurs at specific time intervals.
System: Windows
Code:... 2010-10-02 12:46:40.467625|WARNING |PktHandler | | detected incorrectly running system clock 2010-10-02 12:46:40.467625|WARNING |PktHandler | | detected incorrectly running system clock 2010-10-02 12:46:40.483250|WARNING |PktHandler | | detected incorrectly running system clock 2010-10-02 12:46:40.483250|WARNING |PktHandler | | detected incorrectly running system clock 2010-10-02 12:46:40.483250|WARNING |PktHandler | | detected incorrectly running system clock 2010-10-02 12:46:40.498875|WARNING |PktHandler | | detected incorrectly running system clock 2010-10-02 12:46:40.498875|WARNING |PktHandler | | detected incorrectly running system clock 2010-10-02 12:46:40.514500|WARNING |PktHandler | | detected incorrectly running system clock 2010-10-02 12:46:40.577000|WARNING |PktHandler | | detected incorrectly running system clock 2010-10-02 12:46:40.577000|WARNING |PktHandler | | detected incorrectly running system clock 2010-10-02 12:46:40.577000|WARNING |PktHandler | | detected incorrectly running system clock 2010-10-02 12:46:40.577000|WARNING |PktHandler | | detected incorrectly running system clock 2010-10-02 12:46:40.592625|WARNING |PktHandler | | detected incorrectly running system clock 2010-10-02 12:46:40.592625|WARNING |PktHandler | | detected incorrectly running system clock 2010-10-02 12:46:40.608250|WARNING |PktHandler | | detected incorrectly running system clock 2010-10-02 12:46:40.608250|WARNING |PktHandler | | detected incorrectly running system clock 2010-10-02 12:46:40.608250|WARNING |PktHandler | | detected incorrectly running system clock 2010-10-02 12:46:40.623875|WARNING |PktHandler | | detected incorrectly running system clock 2010-10-02 12:46:40.623875|WARNING |PktHandler | | detected incorrectly running system clock 2010-10-02 12:46:40.623875|WARNING |PktHandler | | detected incorrectly running system clock 2010-10-02 12:46:40.639500|WARNING |PktHandler | | detected incorrectly running system clock 2010-10-02 12:46:40.686375|WARNING |PktHandler | | detected incorrectly running system clock 2010-10-02 12:46:40.717625|WARNING |PktHandler | | detected incorrectly running system clock 2010-10-02 12:46:40.733250|WARNING |PktHandler | | detected incorrectly running system clock 2010-10-02 12:46:40.733250|WARNING |PktHandler | | detected incorrectly running system clock 2010-10-02 12:46:40.733250|WARNING |PktHandler | | detected incorrectly running system clock 2010-10-02 12:46:40.748875|WARNING |PktHandler | | detected incorrectly running system clock 2010-10-02 12:46:40.780125|WARNING |PktHandler | | detected incorrectly running system clock 2010-10-02 12:46:40.780125|WARNING |PktHandler | | detected incorrectly running system clock 2010-10-02 12:46:40.795750|WARNING |PktHandler | | detected incorrectly running system clock 2010-10-02 12:46:40.795750|WARNING |PktHandler | | detected incorrectly running system clock 2010-10-02 12:46:40.795750|WARNING |PktHandler | | detected incorrectly running system clock 2010-10-02 12:46:40.811375|WARNING |PktHandler | | detected incorrectly running system clock 2010-10-02 12:46:40.811375|WARNING |PktHandler | | detected incorrectly running system clock 2010-10-02 12:46:40.811375|WARNING |PktHandler | | detected incorrectly running system clock 2010-10-02 12:46:40.827000|WARNING |PktHandler | | detected incorrectly running system clock 2010-10-02 12:46:40.827000|WARNING |PktHandler | | detected incorrectly running system clock 2010-10-02 12:46:40.827000|WARNING |PktHandler | | detected incorrectly running system clock 2010-10-02 12:46:40.842625|WARNING |PktHandler | | detected incorrectly running system clock 2010-10-02 12:46:40.842625|WARNING |PktHandler | | detected incorrectly running system clock 2010-10-02 12:46:40.842625|WARNING |PktHandler | | detected incorrectly running system clock ...
03-10-2010, 14:31 #15
but my system is windows and the problem appeared in the new beta29 version
Can't conenct to server accounting "detected incorrectly running system clock"
By mralaskaman in forum Linux / FreeBSDReplies: 7Last Post: 10-06-2011, 16:33 -
Detected incorrectly running system clock!
By Cyberwolf. in forum Server SupportReplies: 0Last Post: 18-04-2011, 15:12 -
By SeToY in forum Linux / FreeBSDReplies: 2Last Post: 03-01-2011, 22:52 -
By Sponge-Manu in forum Bug ReportsReplies: 3Last Post: 03-10-2010, 16:14 -
By YJeeper in forum Server SupportReplies: 1Last Post: 02-03-2010, 22:24
