Results 1 to 2 of 2
21-05-2003, 07:10 #1
-= TeamSpeak User =-
- May 2003
- Location
- Taiwan
- 6
[INFO] How to fix webpost 3.1.1 with php4
The original webpost v3.1.1 wouldn't run under php4 due to php4 using HTTP_POST_VARS and HTTP_GET_VARS to retrive HTML form info, the way is different with php3. Therefore, you need to make serveral change on php code to make webpost v3.1.1 run under php4.
Add following line in specified file's top:
**webpost.php**
$server_adminemail = $HTTP_POST_VARS[server_adminemail];
$server_isplinkurl = $HTTP_POST_VARS[server_isplinkurl];
$server_ispname = $HTTP_POST_VARS[server_ispname];
$server_ispcountry = $HTTP_POST_VARS[server_ispcountry];
$server_platform = $HTTP_POST_VARS[server_platform];
$server_version_major = $HTTP_POST_VARS[server_version_major];
$server_version_minor = $HTTP_POST_VARS[server_version_minor];
$server_version_release = $HTTP_POST_VARS[server_version_release];
$server_version_build = $HTTP_POST_VARS[server_version_build];
$server_port = $HTTP_POST_VARS[server_port];
$server_name = $HTTP_POST_VARS[server_name];
$server_uptime = $HTTP_POST_VARS[server_uptime];
$server_password = $HTTP_POST_VARS[server_password];
$server_type1 = $HTTP_POST_VARS[server_type1];
$server_type2 = $HTTP_POST_VARS[server_type2];
$clients_current = $HTTP_POST_VARS[clients_current];
$clients_maximum = $HTTP_POST_VARS[clients_maximum];
$channels_current = $HTTP_POST_VARS[channels_current];
$server_linkurl = $HTTP_POST_VARS[server_linkurl];
$server_queryport = $HTTP_POST_VARS[server_queryport];
**listing.php**
$detail = $HTTP_GET_VARS[detail];
$page = $HTTP_GET_VARS[page];
$sort = $HTTP_GET_VARS[sort];
$direction = $HTTP_GET_VARS[direction];
$showgroup = $HTTP_GET_VARS[showgroup];
**login.php**
$action = $HTTP_POST_VARS[action];
$server = $HTTP_POST_VARS[server];
$servername = $HTTP_POST_VARS[servername];
$nickname = $HTTP_POST_VARS[nickname];
$savenickname = $HTTP_POST_VARS[savenickname];
$loginname = $HTTP_POST_VARS[loginname];
$saveloginname = $HTTP_POST_VARS[saveloginname];
$password = $HTTP_POST_VARS[password];
$savepassword = $HTTP_POST_VARS[savepassword];
$channel = $HTTP_POST_VARS[channel];
$savechannel = $HTTP_POST_VARS[savechannel];
$channelpassword = $HTTP_POST_VARS[channelpassword];
$savechannelpassword = $HTTP_POST_VARS[savechannelpassword];
Than you should be able to use webpost v3.1.1 under php4 now.
NOTE: I didn't check the reason why login window's remember setting cookie has no work yet, it might be cause by different cookie method in php4, I don't know yet. Therefore, if you like remember setting works, you have to check the login.php and someother related file by urself...
21-05-2003, 10:07 #2
-= TeamSpeak Addict =-
- Jun 2002
- 704
Nice to post a fix yet there is a whole section dedicated to webpost and people will rather look for a solution there than in the windows server category. Maybe an admin can move that post?
Another workaround would be to activate "register globals" in php as that is still possible and only since php 4.2 (or something close to that) they have changed the default value to "register globals = false". Yet registring globals can be a security risk which is why it has been deactivated by default.
How can I fix these Webpost fsock problems
By Nemhain in forum [TeamSpeak 2] Addons & ScriptsReplies: 2Last Post: 24-06-2004, 20:49 -
Webpost v4.0.2 doesn't show server (again)
By stevil in forum [TeamSpeak 2] Addons & ScriptsReplies: 0Last Post: 30-07-2003, 02:57
