Results 1 to 3 of 3
Thread: Problem with beta 22
19-07-2010, 18:50 #1
-= TeamSpeak User =-
- Jul 2010
- Location
- WA, USA
- 2
I have Ubuntu 10.04. When I downloaded the current TS3 Beta22 install script, it fails to install. I get a gedit error "gedit has not been able to detect the character encoding.
Please check that you are not trying to open a binary file.
Select a character encoding from the menu and try again."
I have an older script for TS3beta13 which installs ok. But when I try and join my server I have to update it. Update seems to work fine and after update the link on the update box to run TS3 works and TS is working. But after closing if I try and use the TS3client_runscript.sh I get a gedit window with what looks like an incomplete script in it. "#!/bin/bash
export QT_PLUGIN_PATH=.
export LD_LIBRARY_PATH=".:$LD_LIBRARY_PATH"
cd "$(dirname "${0}")"
if [ -e ts3client_linux_x86 ]; then
./ts3client_linux_x86 $@
else
./ts3client_linux_amd64 $@
fi"
If I try and run from the TS3client_linux_x86 nothing happens.
I'm still learning Linux as I'm primarily a Windows person, so please be gentle.
Sir Puma
19-07-2010, 21:19 #2
-= TeamSpeak Addict =-
- Feb 2008
- Location
- Germany, Schorndorf
- 176
check TS3client_runscript.sh with right mousebutton properties. Maybe you can set it to start as program.
regards dabu
19-07-2010, 21:24 #3
- Jul 2010
- Location
- WA, USA
- 2
That helped, it wasn't in the Right Click pop up menu, but there was a check box in the properties. I checked the box, TS3 now runs.
Thanks
Problem Channelwechsel
By Dennis6N2 in forum [TeamSpeak 2] Client SupportReplies: 13Last Post: 12-03-2009, 13:53 -
Teamspeak microfon problem
By xprokiller in forum [TeamSpeak 2] Client SupportReplies: 1Last Post: 30-01-2009, 17:25 -
Problem with Shure SM58 mic
By DaSNooZ in forum [TeamSpeak 2] Client SupportReplies: 8Last Post: 09-12-2008, 13:21 -
Problem logging in as Registered
By dprotas in forum [TeamSpeak 2] Server SupportReplies: 1Last Post: 13-09-2008, 09:32 -
Problem with only specific client
By Grin_Reaper in forum [TeamSpeak 2] Client SupportReplies: 1Last Post: 09-10-2003, 17:36
