Page 1 of 2 12 LastLast
Results 1 to 15 of 20
    Mar 2010
    USA
    13
    Exclamation Please help can't connect
    My ports are open and I have a ddns but people still can't connect to my server
    Feb 2006
    Texas, USA
    4,187
    Mar 2010
    USA
    13
    Wow people don't get it my ports are open!!
    May 2007
    Eastern NC
    1,362
    Any firewall software running on the server?
    Mar 2010
    USA
    13
    My router firewall doesn't block programs just port 113 and nat redirection if I choose and it is allowed through the pc firewall
    Feb 2006
    Texas, USA
    4,187
    If people can't connect then either you stopped your server or there is something blocking the voice port.
    Verify that the ports are indeed forwarded to the correct IP address and then try turning off your anti-virus and firewall completely.
    Mar 2010
    USA
    13
    they are forwarded and turning firewall and antivirus off didnt help
    May 2010
    6,372
    Use this site and test your port
    http://www.canyouseeme.org
    In your local network can you connect to your server ?
    Mar 2010
    USA
    13
    That doesn't work I have a game server that requires open ports and works just fine and the site can't see them either and yes I can connect through my network
    May 2010
    6,372
    Very strange ?
    What error message have your user ?
    They are try with your public IP ?
    Which server version you use ?
    Mar 2010
    USA
    13
    beta25 and failed to connect to server and yes we have tried my ip itself instead of the dns it didnt work
    May 2010
    6,372
    Stupid idea but some time
    Have you try to change the Voip port ?
    Mar 2010
    USA
    13
    no how do I do that?
    May 2010
    6,372
    By query command (by you TS3 client or putty)
    login serveradmin <password>
    use <sid server>
    or
    use port=<server port>
    serveredit virtualserver_port=<the new port>
    Of by the web interface that you find in the addons forum.
    Mar 2010
    USA
    13
    insufficient permissions and cant get the web site to work
  1. second connect doesent work
    By dno829 in forum Windows
    Last Post: 29-06-2010, 14:37
  2. Failed to connect to server
    By xEvAngelx in forum Windows
    Last Post: 07-02-2010, 19:44
  3. connect problems 2
    By leeke23 in forum [TeamSpeak 2] Client Support
    Last Post: 18-12-2007, 13:40
  4. Users occasionally cannot connect
    By Lakusfs in forum [TeamSpeak 2] Server Support
    Last Post: 12-08-2006, 20:03
  5. Can Not Connect Using Quick Connect
    By jmunsters in forum [TeamSpeak 2] Server Support
    Last Post: 15-03-2006, 12:49
