Results 1 to 2 of 2
    Aug 2010
    UK
    Connection dropped
    Hi All,
    I have an issue with getting TS 3 server up and running. I am running a 64 bit 2008 windows server operating system on the computer I want to host the server.
    I have downloaded the TS 3 server software, got it running, opened ports UDP 9987, TCP 30033 and TCP 10011. I have logged into the TS sever on the server machine and entered the serial key generated when you first open the server.
    Now When I connect using the IP address I received from (whatismyip.com) it connects correctly but only for around 10 seconds. It then disconnects me from the server and wont reconnect. If I want a little while I can connect again but it will kick me after around 10 seconds again.
    Anyone got any tips to work out whats going wrong here?
    EDIT-----------------
    Ok a friend of mine has connected to the server. The problem is I cannot connect to the server on a computer on my network. Any help with this?
    Thanks for any help.
    S
    May 2010
    6,372
    It's normal. You can't use your external IP to you connect on your server in your Internal network. It's a security measure on several routers.
    Use the internal IP (192.168.x.x)
  1. TS3 Overlay plugin?
    By KrabKley in forum Plugins
    Last Post: 12-12-2012, 11:42
  2. [On Todo] Servers Disconnects
    By ep1s0d3 in forum Server Support
    Last Post: 02-09-2010, 10:50
  3. Help me Pls! Helft mir bitte!
    By BcJoe in forum Windows
    Last Post: 03-04-2010, 10:32
  4. TeamSpeak 2 Anti-Flood Daemon
    By ScP in forum [TeamSpeak 2] Addons & Scripts
    Last Post: 07-09-2009, 18:27
  5. Connection Timed Out
    By Optiks in forum [TeamSpeak 2] Server Support
    Last Post: 20-01-2009, 12:17
