Results 1 to 4 of 4
    Dec 2009
    The Netherlands
    13
    Permission for viewer
    Hello people,
    I've got a problem regarding a teamspeak3 server wich is running on debian lenny.
    194.145.200.154:9987
    Query port is 10011
    The server is running. And everything works fine.
    But if i want to add the server to a public server list it always shows that the server is offline.
    I know i used the right ports. becouse this are the standart ports.
    Does anyone knows a solution for this problem?
    Thanks in advance.
    Jan 2010
    Catalunya
    2,330
    Use the ServerQuery
    after login, introduce this code.
    use sid=1
    serveredit virtualserver_weblist_enabled=1
    and around 15' chech the WebServerList
    Dec 2009
    The Netherlands
    13
    Well, that is not the problem.
    I have an website where you can add your server, so not the server list of teamspeak.
    such as http://www.gametracker.com
    And i have also an application on my mobile to see how many users are on the server.
    That kind of server listing.
    And that still does not work. And i know that i have set all the right ports and IP adress.
    I hope you understand.
    Do you know a solution for that?
    Jan 2010
    Catalunya
    2,330
    I don't know your web server, but for TSViewer it's necessary:
    In Client Permissions for client = ServerQuery
    set b_virtualserver_servergroup_list
    set b_virtualserver_channelgroup_list
    In your Server folder
    set TSViewer IP in query_ip_whitelist.txt
    I hope it is helpful
  1. Replies: 1
    Last Post: 05-09-2011, 14:03
  2. Replies: 1
  3. Replies: 4
    Last Post: 12-08-2011, 01:41
  4. Permission fo external viewer
    By cagmyers85 in forum Permission System
    Last Post: 22-06-2010, 22:02
  5. Replies: 9
    Last Post: 13-02-2010, 13:08
