Results 1 to 6 of 6
    Apr 2010
    England
    7
    Solved [solved] Problem with non profit license
    Hi, I just transferred from linux to windows and if I have my licensekey.dat in the root it won't start it says:
    2010-08-18 17:21:08.334800|INFO |ServerLibPriv | | Server Version: 3.0.0-beta27 [Build: 12002], Windows
    2010-08-18 17:21:08.334800|INFO |DatabaseQuery | | dbPlugin name: SQLite3 plugin, Version 2, (c)TeamSpeak Systems GmbH
    2010-08-18 17:21:08.334800|INFO |DatabaseQuery | | dbPlugin version: 3.6.10
    2010-08-18 17:21:08.334800|INFO |DatabaseQuery | | checking database integrity (may take a while)
    2010-08-18 17:21:08.350400|INFO |SQL | | pruning old database log entries where timestamp is older than 90 days
    2010-08-18 17:21:08.600000|INFO |Accounting | | Licensing Information
    2010-08-18 17:21:08.600000|INFO |Accounting | | type : Non-profit
    2010-08-18 17:21:08.615600|INFO |Accounting | | starting date : Wed Jul 21 00:00:00 2010
    2010-08-18 17:21:08.615600|INFO |Accounting | | ending date : Thu Jul 21 00:00:00 2011
    2010-08-18 17:21:08.615600|INFO |Accounting | | max virtualservers: 10
    2010-08-18 17:21:08.615600|INFO |Accounting | | max slots : 512
    2010-08-18 17:21:08.646800|INFO |FileManager | | listening on 0.0.0.0:30033
    2010-08-18 17:21:08.740400|INFO |VirtualServer | 1| listening on 0.0.0.0:9987
    2010-08-18 17:21:08.740400|INFO |CIDRManager | | updated query_ip_whitelist ips: 127.0.0.1,
    2010-08-18 17:21:08.740400|INFO |Query | | listening on 0.0.0.0:10011
    2010-08-18 17:21:08.943200|ERROR |Accounting | | too many slots hosted, shutting down!
    2010-08-18 17:21:09.052400|INFO |VirtualServer | 1| stopped
    There is only 1 virtual server and it says too many slots... Yes I restarted it, If I take the file out it starts but I won't be able to go over 32 slots.
    Feb 2006
    Texas, USA
    4,187
    Give it a few hours and try again. It takes about 2-3 hours for the accounting server to purge old data.
    Apr 2010
    England
    7
    What do you mean? It can't be used at the same time?
    Feb 2006
    Texas, USA
    4,187
    If you have a NPL set to 512 slots but close the server and then move the NPL to a new location and restart the server the accounting server thinks you are trying to run 2 servers with the same NPL. If you let the accounting server purge old data (info that it does not receive again when requested) from it's database then it only sees the most current server and not the old (ghost) server.
    Jun 2008
    7,763
    Quote Originally Posted by Alex1095 View Post
    You should shutdown the whole server process with, the command serverprocessstop. This stops all your servers and reports, that no slots are used anymore. So you can avoid, that you get this message.
    This is the normal way, but serverprocessstop is bugged atm (known bug)
    As long, it isnt fixed, please use the command "serverstop sid={serverID}" to stop your server, before you kill the whole process.
    Apr 2010
    England
    7
    Alright, Thanks.
  1. [Resolved] License Key Issue
    By tmm4264 in forum Mac OS X
    Last Post: 28-02-2012, 21:13
  2. [Solved] Non- Profit License transfer
    By Billybob2769 in forum Server Support
    Last Post: 16-05-2010, 17:31
  3. [Solved] "Unable to find valid license key" ... !!???
    By bzImage in forum Linux / FreeBSD
    Last Post: 03-03-2010, 17:13
  4. non-profit license problem
    By jazza in forum Windows
    Last Post: 27-02-2010, 20:03
  5. Replies: 7
    Last Post: 03-02-2010, 19:40
