Page 1 of 2 12 LastLast
Results 1 to 15 of 17
    Jul 2010
    Georgia
    Problem with license key?
    Server works fine until I add license key file, after file is entered the server will start, but no connections are allowed. Server was just deleted and reinstalled today using the newest available download.
    Error log is:
    2010-08-28 02:08:10.309459|INFO |ServerLibPriv | | Server Version: 3.0.0-beta27 [Build: 12002], Windows
    2010-08-28 02:08:10.310436|INFO |DatabaseQuery | | dbPlugin name: SQLite3 plugin, Version 2, (c)TeamSpeak Systems GmbH
    2010-08-28 02:08:10.310436|INFO |DatabaseQuery | | dbPlugin version: 3.6.10
    2010-08-28 02:08:10.310436|INFO |DatabaseQuery | | checking database integrity (may take a while)
    2010-08-28 02:08:10.328989|INFO |SQL | | pruning old database log entries where timestamp is older than 90 days
    2010-08-28 02:08:11.119954|INFO |Accounting | | Licensing Information
    2010-08-28 02:08:11.121907|INFO |Accounting | | type : Non-profit
    2010-08-28 02:08:11.122884|INFO |Accounting | | starting date : Thu Jun 03 00:00:00 2010
    2010-08-28 02:08:11.124837|INFO |Accounting | | ending date : Fri Jun 03 00:00:00 2011
    2010-08-28 02:08:11.125813|INFO |Accounting | | max virtualservers: 10
    2010-08-28 02:08:11.127766|INFO |Accounting | | max slots : 512
    2010-08-28 02:08:11.169756|INFO |FileManager | | listening on 0.0.0.0:30033
    2010-08-28 02:08:11.293771|ERROR |VirtualServer | 1| bind failed on 0.0.0.0:9987
    2010-08-28 02:08:11.295724|ERROR |VirtualSvrMgr | | loading VirtualServer(1) failed to start, error: unable to bind network port
    2010-08-28 02:08:11.337714|INFO |VirtualServer | 1| stopped
    2010-08-28 02:08:11.340643|INFO |CIDRManager | | updated query_ip_whitelist ips: 127.0.0.1,
    2010-08-28 02:08:11.342596|INFO |Query | | listening on 0.0.0.0:10011
    Anyone solved this yet?
    If it helps, server wasn't restarted after old teamspeak was removed. Thinking about trying that next.
    Here's the functioning log without the key:
    2010-08-28 02:08:37.463971|INFO |ServerLibPriv | | Server Version: 3.0.0-beta27 [Build: 12002], Windows
    2010-08-28 02:08:37.464948|INFO |DatabaseQuery | | dbPlugin name: SQLite3 plugin, Version 2, (c)TeamSpeak Systems GmbH
    2010-08-28 02:08:37.464948|INFO |DatabaseQuery | | dbPlugin version: 3.6.10
    2010-08-28 02:08:37.465924|INFO |DatabaseQuery | | checking database integrity (may take a while)
    2010-08-28 02:08:37.483501|INFO |SQL | | pruning old database log entries where timestamp is older than 90 days
    2010-08-28 02:08:37.513773|WARNING |Accounting | | Unable to find valid license key, falling back to limited functionality
    2010-08-28 02:08:37.567480|INFO |FileManager | | listening on 0.0.0.0:30033
    2010-08-28 02:08:37.678801|INFO |VirtualServer | 1| listening on 0.0.0.0:9987
    2010-08-28 02:08:37.681731|INFO |CIDRManager | | updated query_ip_whitelist ips: 127.0.0.1,
    2010-08-28 02:08:37.684660|INFO |Query | | listening on 0.0.0.0:10011
    May 2010
    6,372
    Have you stopped your server before add the licence file ?
    Quote Originally Posted by TheMinz
    Hi, looks like your system cannot bind the ports to Teamspeak because they are already in use.
    Did you shut down the previous instance of the server before starting this one?
    Jul 2010
    Georgia
    We closed it before adding the license, if that's what your asking
    May 2010
    6,372
    what is your start command line ?
    Have set an ts3server.ini file ?
    Jul 2010
    Georgia
    Just using the defaults, so no ini file made.
    Start the sever with the standard executable in the folder.
    We did the same with the older version, and it worked fine.
    Sep 2010
    UK
    i just got my license key
    Followed the instructions
    TS works fine and allows people to join, but still only get max 32 clients
    error log in logs
    2010-09-27 21:35:22.506835|INFO |ServerLibPriv | | Server Version: 3.0.0-beta28 [Build: 12264], Windows
    2010-09-27 21:35:22.508789|INFO |DatabaseQuery | | dbPlugin name: SQLite3 plugin, Version 2, (c)TeamSpeak Systems GmbH
    2010-09-27 21:35:22.509765|INFO |DatabaseQuery | | dbPlugin version: 3.6.21
    2010-09-27 21:35:22.510742|INFO |DatabaseQuery | | checking database integrity (may take a while)
    2010-09-27 21:35:22.542968|INFO |SQL | | pruning old database log entries where timestamp is older than 90 days
    2010-09-27 21:35:22.685546|WARNING |Accounting | | Unable to find valid license key, falling back to limited functionality
    2010-09-27 21:35:22.863281|INFO |FileManager | | listening on 0.0.0.0:30033
    2010-09-27 21:35:23.429687|INFO |VirtualServer | 1| listening on 0.0.0.0:9987
    2010-09-27 21:35:23.437500|INFO |CIDRManager | | updated query_ip_whitelist ips: 127.0.0.1,
    2010-09-27 21:35:23.449218|INFO |Query | | listening on 0.0.0.0:10011
    have restarted pc running windows 7 32bit
    have rolled windows back 5 days reinstalled and input the .dat file in again still only get max 32 slots
    have tried using putty and deleting server and recreating server get the error client slots exceeded
    spent 5 hours on this and still no luck
    Jun 2008
    7,762
    This was a linux forum!
    Wehre did you place the license.dat? You have to put that file into the main folder of your server.
    Nov 2010
    CZE
    Licensekey.dat Problem
    Good morning,
    Have TS3 server runing under Debian stable x86
    Server works fine until I add Licnesekey.dat file in to root folder of "instalation" (is in same directory like ts3server_startscript.sh)
    this is log entry WITH licensekey file (doesnt work)
    root@Galadriel ~ $ cat /home/ts/teamspeak3-server_linux-x86/logs/ts3server_2010-
    11-29__06_03_06.469087.log
    2010-11-29 06:03:06.469594|INFO |ServerLibPriv | | Server Version: 3.0.0-be
    ta30 [Build: 12998], Linux
    2010-11-29 06:03:06.470332|INFO |DatabaseQuery | | dbPlugin name: SQLite
    2010-11-29 06:03:06.470514|INFO |DatabaseQuery | | dbPlugin version: 3.7.3
    2010-11-29 06:03:06.471142|INFO |DatabaseQuery | | checking database integr
    2010-11-29 06:03:06.504776|INFO |SQL | | pruning old database log
    log entry WITHOUT licensekey file (does work)
    11-29__06_04_32.447596.log
    2010-11-29 06:04:32.448096|INFO |ServerLibPriv | | Server Version: 3.0.0-be
    2010-11-29 06:04:32.448904|INFO |DatabaseQuery | | dbPlugin name: SQLite
    2010-11-29 06:04:32.449084|INFO |DatabaseQuery | | dbPlugin version: 3.7.3
    2010-11-29 06:04:32.449702|INFO |DatabaseQuery | | checking database integr
    2010-11-29 06:04:32.481153|INFO |SQL | | pruning old database log
    2010-11-29 06:04:32.489539|WARNING |Accounting | | Unable to find valid lic
    2010-11-29 06:04:32.541570|INFO |FileManager | | listening on 0.0.0.0:300
    33
    2010-11-29 06:04:32.702494|INFO |VirtualServer | 1| listening on 0.0.0.0:998
    7
    2010-11-29 06:04:32.704185|INFO |CIDRManager | | updated query_ip_whiteli
    st ips: 127.0.0.1,
    2010-11-29 06:04:32.705635|INFO |Query | | listening on 0.0.0.0:100
    11
    So 1st thing is that with licensekey file log is not complete and I think starting procedure just crash and server doesnt start at all even when status command says that "server is running"
    2nd Without licensekey it work but with only 32slots
    I will be glad for any help that you may offer thank you
    PS: I did stop server b4 adding licensekey file
    Dec 2009
    The Game!
    236
    Hi vodouch,
    Your problem is probably related to the read-write permissions.
    Make sure your licensefile has at least CHMOD 644
    (this error has also been covered a few times already in other threads, your error is another one as the one in Sorrisīs post)
    Also :
    Quote Originally Posted by dante696
    Meaning the thread is now in a Windows forum and does not match your OS.
    Nov 2010
    CZE
    Still nothing
    I changed rights to 644 and still smae problem nothink changed
    Nov 2010
    CZE
    Quote Originally Posted by TheMinz View Post
    Hi vodouch,
    Also :
    May be if you can tell me where problem was soved I will it will be faster :-)
    Nov 2010
    Arizona
    21
    Exclamation
    Lic. Key for the non profit for my family and friends TS3 server im running
    Server Windows 2008 Enterprise R2 on a home network with Bandwith of
    http://www.pingtest.net/result/29195673.png
    http://www.speedtest.net/result/1051430590.png
    to my farthest Family Member
    I got the Lic. added it to the root file and it is stating that i have 512 on the server log, but the server still says 32 ?? is this right or is there something else i need to do??
    2010-11-23 22:30:51.146000|INFO |ServerLibPriv | | Server Version: 3.0.0-beta30 [Build: 12998], Windows
    2010-11-23 22:30:51.161600|INFO |DatabaseQuery | | dbPlugin name: SQLite3 plugin, Version 2, (c)TeamSpeak Systems GmbH
    2010-11-23 22:30:51.161600|INFO |DatabaseQuery | | dbPlugin version: 3.7.3
    2010-11-23 22:30:51.192800|INFO |DatabaseQuery | | checking database integrity (may take a while)
    2010-11-23 22:30:51.598400|INFO |SQL | | pruning old database log entries where timestamp is older than 90 days
    2010-11-23 22:30:52.908800|INFO |Accounting | | Licensing Information
    2010-11-23 22:30:52.908800|INFO |Accounting | | type : Non-profit
    2010-11-23 22:30:52.908800|INFO |Accounting | | starting date : Tue Nov 23 00:00:00 2010
    2010-11-23 22:30:52.908800|INFO |Accounting | | ending date : Wed Nov 23 00:00:00 2011
    2010-11-23 22:30:52.908800|INFO |Accounting | | max virtualservers: 10
    2010-11-23 22:30:52.908800|INFO |Accounting | | max slots : 512
    2010-11-23 22:30:52.955600|INFO |FileManager | | listening on 0.0.0.0:30033
    2010-11-23 22:30:53.439200|INFO |VirtualServer | 1| listening on 0.0.0.0:9987
    2010-11-23 22:30:53.439200|INFO |CIDRManager | | updated query_ip_whitelist ips: 127.0.0.1,
    2010-11-23 22:30:53.439200|INFO |Query | | listening on 0.0.0.0:10011
    this is JIC to see what I'm doing to the other side of the world
    http://www.pingtest.net/result/29195852.png
    http://www.speedtest.net/result/1051455796.png
    Last edited by Lowded; 30-11-2010 at 16:14. Reason: adding pingtest all from my home Server
    Feb 2006
    Texas, USA
    4,187
    @Lowded
    Your log shows the server recognizes your license. Now you need to edit your server and change the max users You can go as high as 512.
    Nov 2010
    Arizona
    21
    Red face
    @Lowded
    ok ok then sorry for the DUMB ?? LOL AGAIN
    i was in a Head Trama crash 10-24-09 and , im still relearning all this , where and how do i edit that ???
    Feb 2006
    Texas, USA
    4,187
    No worries Go to TOOLS->EDIT VIRTUAL SERVER
  1. Push to Talk problem setting key
    By Toad465 in forum General Questions
    Last Post: 03-06-2011, 15:24
  2. Replies: 10
    Last Post: 14-04-2010, 16:16
  3. non-profit license problem
    By jazza in forum Windows
    Last Post: 27-02-2010, 20:03
  4. Non-Profit License Problem
    By Raptor902 in forum Server Support
    Last Post: 22-02-2010, 22:44
  5. License Key not found
    By sonofdresa in forum Server Support
    Last Post: 22-12-2009, 03:48
