Results 1 to 13 of 13
    Aug 2010
    8
    Question Security level - how is it determined/increased [technical]
    First of all, I know what (dis-)advantages high/low minimum security levels have and the general idea of the identity system (private/public key based).
    However, I'd like to know what's calculated/done when increasing the security level.
    May 2010
    6,372
    The calculation and the complexity of your identification key (uid) on the server
    Aug 2010
    8
    I realize that I'm curious about the technical details.
    Especially since that calculation must be something not resulting in the public key changing as that would invalidate your access on all servers.
    May 2010
    6,372
    You can understand that it will not be explain here
    Aug 2010
    8
    As you might know, security by obscurity is a horrible approach and hopefully not the one they used in TS3.
    So if it actually relies on a calculation which takes lots of time and not a simple "wait for x seconds and then bump the security level" it's as secure as e.g. RSA (which is secure as long as certain mathematical operations cannot be done much faster than currently possible). In this case the TS developers could even post the *sourcecode* of the security level system without making it insecure.
    May 2010
    6,372
    Yes you right, I'm going to ask at Microsoft how he generate the windows seven key.
    Aug 2010
    8
    Serial numbers are usually generated/validated with a simple algorithm (which certainly does not take minutes or even hours to generate a single key) and do not rely on strong cryptography. So that's a completely different thing.
    I think all serial numbers rely on obscurity - that's why you can write keygens for most applications requiring a serial number - or on online activation which is safe because the key can be verified against a list of all keys ever sold instead of running it through an algorithm.
    Mar 2010
    ger
    30
    That is the absolute worst attitude to security you can possibly have. If it won't be discussed here, it will be discussed somewhere else. Since your "security" algorithm is apparently worthless, I'll just save everyone the hassle and disable it on my server. Without peer review you're only keeping the honest people honest.
    Feb 2006
    Texas, USA
    4,187
    This isn't a method to secure a server it's merely a method to deter those that like to repeatedly join a server w/ new UIDs.
    Jul 2002
    2,836
    The method that is used is based on hashcash: http://en.wikipedia.org/wiki/Hashcash
    You think my answer is stupid ? Read This:
    http://www.catb.org/~esr/faqs/smart-...ons.html#intro
    In a world without fences and walls - who needs windows and gates ?
    Feb 2006
    Texas, USA
    4,187
    Hashcash is a proof-of-work system designed to limit email spam and denial of service attacks.
    This is exactly what the security level is for on Teamspeak 3. The idea is to limit the spammers and people who get banned but create a new identity and come back. If you make them wait to raise their security level they will probably get bored and move on.
    Mar 2010
    ger
    30
    Thank you. I'm always trying to learn something new!
    Feb 2006
    Texas, USA
    4,187
    Not a problem! Hope that was the info you needed
  1. Improved Security Level - Can no longer connect to server
    By sniperfodder in forum Client Support
    Last Post: 19-07-2011, 11:14
  2. Replies: 3
    Last Post: 26-03-2010, 20:56
  3. "Soft" Security level
    By PatrickW in forum Suggestions and Feedback
    Last Post: 17-02-2010, 15:08
  4. Stealing nicknames
    By Freds in forum Permission System
    Last Post: 20-01-2010, 16:31
  5. What is the security level for
    By Merlok in forum General Questions
    Last Post: 21-12-2009, 10:33
