Results 1 to 15 of 15
    Oct 2010
    7
    I group modify power
    Hi Community,
    at first, iam sorry for my bad english, i can not speak english very well because iam from Germany
    now my problem:
    yesterday i wanted to change the right "kick from server power" for channel admins.
    But there was an error message: insufficient client permissions (gescheitert an i_group_modify_power)
    it should be changeable because iam server admin.
    I searched for the error an found this: i_client_modify_power for server admins, I also could not change this.
    And this error message again:insufficient client permissions (gescheitert an i_group_modify_power)
    I tryed to change other rights o my Server, there are some I could change and some I could not change.
    How can I give me the right to change all rights on my server ?
    Sry but I cannot explain so good in english :/
    MfG Matscher
    Jan 2010
    Catalunya
    2,330
    Can you enable i_group_modify_power in:
    Permissions > Server Groups > Server Admin > Group > ...
    if you can, set value = 75, and I hope all is right.
    If you can't, if your Server is hosted, you need to contact with the hoster for enable this permisssion.
    Oct 2010
    7
    I cant change i_group_modify_power
    This server is on my PC
    but it is on 75
    Jan 2010
    Catalunya
    2,330
    Tell me the values in SA > Group > Modify > for...
    i_group_needed_modify_power
    also
    i_permission_modify_power
    b_permission_modify_power_ignore
    Oct 2010
    7
    i_group_modify_power 75
    i_group_needed_modify_power 75
    i_permission_modify_power 75
    b_permission_modify_power_ignore --> it isnt enabled and i can not enable this:
    error message: insufficient permission modify power
    Jan 2010
    Catalunya
    2,330
    Everything seems fine
    Check this:
    In the Channels_Tree, click on your name, and look, in the rigt window, that says in Server Groups:
    - Normal ... ?
    - Guest ... ?
    - Admin Server Query ... ?
    - Server Admin ... ?
    Oct 2010
    7
    Server Admin(6)
    Jan 2010
    Catalunya
    2,330
    Quote Originally Posted by Matscher View Post
    check: Channel Groups > Channel Admin > Client > Admin > ...
    i_client_kick_from_server_power
    i_client_needed_kick_from_server_power
    Oct 2010
    7
    that rights are not activated
    but i can not activate them: insufficient group modify power
    Jan 2010
    Catalunya
    2,330
    check: Channel Groups > Channel Admin > Group > Modify > ...
    i_group_needed_modify_power = ??? set 75
    Oct 2010
    7
    it was 75
    i can not change it
    Jan 2010
    Catalunya
    2,330
    My last idea for today.
    Login like AdminServerQuery, has a max level permissions.
    Use Telnet with this code:
    login serveradmin <password>
      use sid=<server ID>
      servergroupaddclient sgid=2 cldbid=<your Database ID>
    Oct 2010
    7
    when I logged in as an Query Admin, how to change the rights ?
    Jan 2010
    Catalunya
    2,330
    When you are logged, you are all rights.
    Jun 2008
    7,763
    Let me clarify something.
    When your server still has no i_group_auto_update_type set on your groups, then I would suggest to install the server with a new databse.
    Even your Server Query Admin can't set it without the permision b_permission_modify_power_ignore enabaled.
    You need the grant value ,y ou can see behind your permission.
    This permission is available since server version 23 and it adds new permissions and their grant values to the groups.
    All these new permisions like kick from server / channel, change an icon etc.
    The other way to do this, is to open the databse and change this values per hand or script.
  1. Permission channel admin
    By Immortals in forum Permission System
    Last Post: 29-09-2010, 10:49
  2. Group Modify Power?
    By Omlet in forum Permission System
    Last Post: 11-09-2010, 06:34
  3. I'm a newb and yes, I'm confused.
    By Trekkan in forum Permission System
    Last Post: 23-06-2010, 17:19
  4. [Solved] insufficient group modify power
    By MrT99 in forum Permission System
    Last Post: 01-03-2010, 17:30
  5. The New Permission Documentataions
    By willy_sunny in forum Permission System
    Last Post: 23-02-2010, 20:56
