Results 1 to 3 of 3
    Oct 2008
    USA
    20
    After Remote Desktop no sound/mic
    After I close remote desktop go back on my computer to use teamspeak the sound nor microphone works, I have to reset it with selecting one that doesn't work at all. Than put it back to the one that does to get my sound plus microphone to work. I'm not sure if anyone else has a issue like this but I ensure you this happens.
    O/S - Windows 7 Professional. x64
    Sound card - Realtek HD audio.
    Headset - Plantronics usb controlled.
    Feb 2006
    Texas, USA
    4,182
    Is this because your capture/playback profile is de-selected? You can right click on the top server tab and select the capture/playback profile you need to use.
    May 2007
    Eastern NC
    1,771
    Other option is that if you don't need the audio from your remote computer while using from elsewhere is to adjust the Remote Audio setting on local resources tab. Set it to "leave audio at remote computer" or "Play on remote computer". This will prevent the change in the audio devices on the remote computer.
  1. Replies: 1
    Last Post: 19-01-2010, 23:34
  2. TeamSpeak Client access with remote desktop
    By dnfw_megatron in forum [TeamSpeak 2] Client Support
    Last Post: 20-06-2007, 21:33
  3. please help someone
    By theundead67 in forum [TeamSpeak 2] Server Support
    Last Post: 31-03-2007, 04:53
  4. Need help with remote server access
    By Dakon in forum [TeamSpeak 2] Server Support
    Last Post: 16-11-2005, 11:29
  5. Mysql Oddity question regarding remote DB
    By RikardF in forum [TeamSpeak 2] Server Support
    Last Post: 02-06-2004, 12:15
