Results 1 to 4 of 4
Thread: Problem with Userrights
16-11-2010, 13:55 #1
-= TeamSpeak User =-
- Nov 2010
- Location
- Germany
- 10
I have one question to my TS3 Server (Server Release 3.0.0-beta28)
I have added on emore group in my server means "Members"
The guest group have the rights after the installation
Only: i_group_needed_modify_power 75
The Member group have:
i_group_needed_modify_power 50
i_group_needed_member_add_power 50
i_group_needed_member_remove_power 50
My problem is: An user came into ts. The user is in the guest group. In the log i see, that this user added himself to group Member. Where is the failure?
17-11-2010, 18:49 #2
-= TeamSpeak Fanatic =-
- Jan 2010
- Location
- Secret Base in Arctic Region
- 1,187
As said on german forum, you are the one who failed
(and possible solution)
17-11-2010, 18:55 #3
-= TeamSpeak Guru =-
- May 2010
- 6,372
Update your server to beta 29 (or beta 30-pre)
Originally Posted by RedDr@gon
For guest group :
Set i_group_member_add_power < 50
Add :
Don't foget to set correctly i_group_auto_update_type
18-11-2010, 09:00 #4
- Jan 2010
- Location
- 1,187
Was solved on said forum.
He thought that member_add_power / member_remove_power on channelgroup level would be only for channel groups.
By default CA have power of 50, guests can create channels, so they could make themselves member
Teamspeak microfon problem
By xprokiller in forum [TeamSpeak 2] Client SupportReplies: 1Last Post: 30-01-2009, 17:25 -
Problem with Shure SM58 mic
By DaSNooZ in forum [TeamSpeak 2] Client SupportReplies: 8Last Post: 09-12-2008, 13:21 -
Problem logging in as Registered
By dprotas in forum [TeamSpeak 2] Server SupportReplies: 1Last Post: 13-09-2008, 09:32 -
Strange connection problem... please help.
By Frostfire in forum [TeamSpeak 2] Client SupportReplies: 6Last Post: 19-07-2006, 10:53 -
Problem with only specific client
By Grin_Reaper in forum [TeamSpeak 2] Client SupportReplies: 1Last Post: 09-10-2003, 17:36
