Results 1 to 7 of 7
29-11-2010, 21:22 #1
-= TeamSpeak User =-
- Nov 2010
- Location
- Germany
- 2
[no bug] Teamspeak automatically sets system-sound lvls to 50%
Hi folks i got a problem with Teamspeak3....
(well i use the program now since it got out and never had this problem until today - and i didnt change anything on my system....)
When i connect to my ts3-server and anybody / me is talking, all other audio-output from any program is lowered to 50% (i can see this when looking at the audio-mixer from windows (taskbar))!
There is absolutely nothing i can do to let the system not set it down but exiting teamspeak.
I tried to go to:
1. TS -> options -> capture -> uncheck "echo reducing" (my client is german so buttons may be called else)
2. TS -> options -> capture -> advanced options -> uncheck "automatic voice-normalization" (dont know the engl. word)
3. Win -> system -> sound -> communication -> check "do nothing" (sound-options for voice-over-ip (phone) sounds -> 4 boxes where u can set all sounds to be muted when having a call or reducing or doing nothing)
Whatever i do .. even if i set everywhere to not reduce sounds for other applications than ts - all time someone talks to me or i talk in ts all other sounds are reduced to 50% ... it's really annoying when u listen to music and all time u speak or someone else speaks your music and everything goes to 50% and 10 sec later to normal again .... im going crazy because i cannot change this in any way but exiting teamspeak! ....
Anyone who can help with this ?
29-11-2010, 21:28 #2
-= TeamSpeak Lover =-
- Nov 2004
- Location
- Germany
- 75
settings->plugins. select volume control, then Settings
29-11-2010, 21:34 #3
- Nov 2010
- Location
- Germany
- 2
weeeee, thanks a lot dude ... i didn't know there is a plugin that affects this!
I tried so much things but never looked at the plugins!
Problem solved
08-12-2010, 00:30 #4
- Dec 2010
- Location
- Spain
- 1
Volumen windows
English:
Teamspeak 3 lowers the volume of other applications to 50%.
As I can solve this problem?
Sorry for my English, translator of google.
*** spanish part deleted ***
*** This forum is english only! ***Last edited by dante696; 08-12-2010 at 11:31.
11-12-2010, 15:34 #5
- Mar 2003
- Location
- Miami, FL
- 16
i have the same problem anyone found a solution?
11-12-2010, 18:05 #6
-= TeamSpeak Fanatic =-
- Feb 2006
- Location
- Texas, USA
- 4,187
Check to see if your volume control plug-in is active. If it is try turning it off.
11-12-2010, 21:23 #7
- Mar 2003
- Location
- Miami, FL
- 16
i have turn that off/on/disable/uninstall and still does it, is driving me crazy
Linux server dependecies
By nwerensteijn in forum [TeamSpeak 2] Server SupportReplies: 79Last Post: 05-09-2007, 21:23 -
database problem
By zionahead in forum [TeamSpeak 2] Client SupportReplies: 7Last Post: 29-08-2007, 04:05 -
TeamSpeak picks up system output sound
By Cunjo in forum [TeamSpeak 2] Client SupportReplies: 11Last Post: 15-05-2007, 15:39 -
TS-Server auf MySql umstellen (Hilfe)
By Rocketwulf in forum [TeamSpeak 2] Server SupportReplies: 5Last Post: 24-01-2007, 08:18 -
Teamspeak needs to release higher codecs, at least 44k
By Gnomore in forum [TeamSpeak 2] General QuestionsReplies: 21Last Post: 08-08-2005, 21:17
