Results 1 to 5 of 5
Thread: Need Help please.
22-12-2010, 23:43 #1
-= TeamSpeak User =-
- Dec 2010
- Location
- NSW
- 8
Need Help please.
Hey whoever is reading this thread i was trying to make a ts3 but i dont get the portforwarding because i have trend micro security and in fire wall there is heaps of TCP/UDP files and i dont know which one to use and change.
Also do you guys sponsor ts3 servers because me and my clan are really needing one it wont just be for us we will let other people in and all that we need it for scrimming and so on.
23-12-2010, 02:45 #2
-= TeamSpeak Fanatic =-
- Feb 2006
- Location
- Texas, USA
- 4,187
Port forwarding info
http://forum.teamspeak.com/showthread.php?t=56314
You need to ensure that your voice port is set to UDP in Trend Micro in order to allow people to connect. If you want to use other services like file transfer you need to forward the appropriate port using TCP.
Rental Server info
http://sales.tritoncia.com/ts3_hosters.php
23-12-2010, 05:27 #3
- Dec 2010
- Location
- NSW
- 8
on trend micro i go personal firewall controls then settings then advanced settings then network protocol control then there is a WHOLE LOOONNNGGG list of different ones how am i meant to know which 1 is right 1? All the protocols r either TCP,UDP or TCP/UDP
23-12-2010, 16:10 #4
- Feb 2006
- Location
- Texas, USA
- 4,187
You need to go to PROGRAM CONTROL not NETWORK CONTROL
There you can select the program you need to manage.
24-12-2010, 19:51 #5
- May 2006
- Location
- Europe/Czech Rep.
- 1,299
is there something like buttons and titled Add port or Add program (forget what is in list)
and with
- Add program way, you will need to select ts3server....exe
- Add port way, you will need to add 9987/udp and 30033/tcp from everyone to your pc.
This is assuming you have default configuration of ts3server.
merge these information
- this post or
- the FAQ info about which ports for ts3server or
- the above forum links (poisonpanik)
and
- this google result http://esupport.trendmicro.com/3/How...curity-20.aspxLast edited by Tomas; 24-12-2010 at 23:31. Reason: damm port\
