Page 1 of 2 12 LastLast
Results 1 to 15 of 23
    Jan 2011
    Chicago, IL
    Solved Continious connect/disconnect from unknown clients.
    What you see below is just a short copy/paste of the messages I see in my TS3 status location. It is a continous connect/reconnect/dropped/etc.
    Who or why are IP's able to hit my TS3 server and cause this disruption and how do I alter the settings to dissallow someone from doing this.
    I have tried entering 68.232.*.* --- (an example) to ban the range but I still see the connections trying to be made.
    Please assist me and I will be most greatful - thank you in advance.
    <08:27:25> "Unknown from 68.232.160.112:35210" dropped (connection lost)
    <08:28:52> "Unknown from 68.232.167.61:56274" connected
    <08:28:53> "Unknown from 68.232.167.61:56274" dropped (connection lost)
    <08:30:27> "Unknown from 212.187.246.208:37105" connected
    <08:30:27> "Unknown from 212.187.246.208:37105" dropped (connection lost)
    May 2007
    Eastern NC
    1,378
    If you signed up for a TS viewer like site that is the site getting info about your server.
    Jan 2011
    Chicago, IL
    Oh...
    Well that makes sense.. I am going to have to ask the other admins about that.
    Is there a way to disable those connections showing on the bottom (if that is the case)
    Another thing is --- when they connect disconnect you see "unknown host" show up in the channel for about half a second then its' gone. So is that what it is?
    Thanks Screech!
    May 2007
    Eastern NC
    1,378
    Settings -> options -> application pane. Uncheck show query clients.
    Nov 2011
    6
    Lost Connections
    I have problem with my server.
    Problem is, that some clients want to connect and soon they connect stright away they getting connection lost.
    There is some logs!
    <23:31:32> "Unknown from 208.167.245.128:45889" connected
    <23:31:33> "Unknown from 208.167.245.128:45889" dropped (connection lost)
    <23:33:27> "Unknown from 208.167.242.82:45261" connected
    <23:33:27> "Unknown from 208.167.242.82:45261" dropped (connection lost)
    <23:34:35> "Unknown from 62.233.252.140:45439" connected
    <23:34:35> "Unknown from 62.233.252.140:45439" disconnected (disconnecting)
    <23:35:35> "Unknown from 208.167.246.5:35775" connected
    <23:35:35> "Unknown from 208.167.246.5:35775" dropped (connection lost)
    <23:37:12> "Unknown from 85.214.124.238:42641" connected
    <23:37:12> "Unknown from 85.214.124.238:42641" disconnected (disconnecting)
    <23:37:29> "Unknown from 68.232.160.108:40110" connected
    <23:37:29> "Unknown from 68.232.160.108:40110" dropped (connection lost)
    <23:39:26> "Unknown from 208.167.247.100:44691" connected
    <23:39:27> "Unknown from 208.167.247.100:44691" dropped (connection lost)
    <23:41:28> "Unknown from 208.167.247.210:39896" connected
    <23:41:28> "Unknown from 208.167.247.210:39896" dropped (connection lost)
    May 2006
    Europe/Czech Rep.
    1,299
    Do you know anything about your server? Do you know how is it connected to the internet? where is it? Mind sharing?
    Don't you wanna fix my car? It broke ! And I cannot transport anyone using it.
    Nov 2011
    6
    I want to get support, not some idiots answares....
    May 2006
    Europe/Czech Rep.
    1,299
    Quote Originally Posted by Marvix View Post
    well if you did not understand the part where I asked you about usuall details of your setup then read the forum advices & rules
    http://forum.teamspeak.com/announcement.php?f=100&a=51
    I recommend you headline When Posting: which with minor imagination could be used for serverside.
    server version? Is it in serverhouse or on home pc/internet connection? What is the firewall setup on the machine where ts3server runs? Is there some router/modem or additional firewall between that machine and internet users on your side?
    I know that both my lines of previous post were in joking fashion but one of them asked the details described in that announcement.
    It is just annoying that someone call an idiot others that have to ask same questions over and over again.
    If you are going to call people idiots, I do not think you should ever run a server or service for others.
    Nov 2011
    6
    Okey,
    sorry about that... ; /
    My server is on VPS linux debian. I dont think so there any firewall will block. Im not sure is it any matter but server got more than 50days UPTIME.
    Cuz
    Jan 2010
    1,346
    Quote Originally Posted by Tomas View Post
    Please, answer the quoted questions...
    May 2010
    6,372
    The log (from your first post) show us query connection from an external script or a person.
    There is a viewer (like tsviewer.com) on your website or something like that ?
    May 2006
    Europe/Czech Rep.
    1,299
    Quote Originally Posted by florian_fr40 View Post
    Even if that would be the case that doesn't explain "connection lost".
    Perhaps someone is scanning his VPS, as it is normal on internet nowadays.
    May 2010
    6,372
    In fact not exactly. Take the case someone scan his VPS with a script (or tool). If the script close the connection whitout send the "quit" query command, the result is "dropped connection lost"
    Nov 2011
    6
    So what should i do?
    Nov 2011
    Unknown IP
    This started yesterday and hasnt stopped no one else sees this but me
    <17:46:38>"[BWFZ] Gutten" connected to channel "Lobby"
    <17:48:24>"Unknown from 85.214.124.238:54749" connected to channel "Lobby"
    <17:48:24>"Unknown from 85.214.124.238:54749" disconnected (disconnecting)
    <17:48:32>"Unknown from 68.232.160.205:46039" connected to channel "Lobby"
    <17:48:32>"Unknown from 68.232.160.205:46039" dropped (connection lost)
    <17:50:43>"Unknown from 63.210.149.254:59289" connected to channel "Lobby"
    <17:50:43>"Unknown from 63.210.149.254:59289" dropped (connection lost)
    <17:52:17>"Unknown from 85.214.124.238:41157" connected to channel "Lobby"
    <17:52:17>"Unknown from 85.214.124.238:41157" disconnected (disconnecting)
    <17:52:52>"Unknown from 68.232.167.23:56108" connected to channel "Lobby"
    <17:52:52>"Unknown from 68.232.167.23:56108" dropped (connection lost)
    <17:55:05>"Unknown from 4.79.145.82:44720" connected to channel "Lobby"
    <17:55:05>"Unknown from 4.79.145.82:44720" dropped (connection lost)
    <17:56:08>"Unknown from 85.214.124.238:39414" connected to channel "Lobby"
    <17:56:08>"Unknown from 85.214.124.238:39414" disconnected (disconnecting)
    <17:58:16>"Unknown from 217.163.30.205:45343" connected to channel "Lobby"
    <17:58:16>"Unknown from 217.163.30.205:45343" dropped (connection lost)
    <17:59:48>"Unknown from 85.214.124.238:46426" connected to channel "Lobby"
    <17:59:48>"Unknown from 85.214.124.238:46426" disconnected (disconnecting)
    <18:00:22>You switched from channel "Lobby" to "Broz With Froz"
    <18:00:31>"Unknown from 68.232.167.62:55065" connected to channel "Lobby"
    <18:00:31>"Unknown from 68.232.167.62:55065" dropped (connection lost)
  1. All clients disconnect on MySQL export with phpMyAdmin
    By Slater in forum Server Support
    Last Post: 13-11-2010, 04:53
  2. [solved] Unknown connect - timeout
    By -Striker- in forum Linux / FreeBSD
    Last Post: 30-08-2010, 12:53
  3. Problem: Disconnect des Clients während Spiel
    By TeacherPreacher in forum [TeamSpeak 2] Client Support
    Last Post: 18-03-2003, 14:25
  4. I connect and then I disconnect (ts 1.5)
    By Tigercop in forum [TeamSpeak Classic] General Questions
    Last Post: 09-02-2003, 19:39
  5. connect then disconnect
    By MASSR in forum [TeamSpeak Classic] General Questions
    Last Post: 22-11-2002, 09:15
