Results 1 to 4 of 4
06-03-2011, 12:51 #1
-= TeamSpeak User =-
- Mar 2011
- 2
Changing server port does not work
Hi @all
i have a little problem with my ts3 installation. I'd like to change the standard ports but it just ignores my inputs in the ts3server.ini!
what I did:
1. create a ts3server.ini
2. changed startscript parameter: OMMANDLINE_PARAMETERS="inifile=ts3server.ini"
3. changed ports in the ts3server.ini:
The IP's are of course only placeholders but if I put wrong IP's in there the server wont start, which means that the ini-file is somehow workingmachine_id=
default_voice_port=8000
voice_ip=xxx.xxx.xxx.xxx
licensepath=
filetransfer_port=8001
filetransfer_ip=xxx.xxx.xxx.xxx
query_port=8002
query_ip=xxx.xxx.xxx.xxx
dbplugin=ts3db_sqlite3
dbpluginparameter=
dbsqlpath=sql/
logpath=logs
logquerycommands=1
The problem is now, that my server still runs on 9978.
I hope somebody can help, I really hate standard ports
Ah btw. I'm running Ubuntu Server 10.04Last edited by Wizardman; 07-03-2011 at 16:33.
06-03-2011, 19:47 #2
-= TeamSpeak Fanatic =-
- Dec 2009
- Location
- Germany
- 1,382
Have you tried to change the Port directly in the Database or with an WebInterface?
07-03-2011, 02:57 #3
Default port is only used the first time you started TS3 server. Now that you have the server running on 9987 changing voice port in the INI has no impact on that server. You need to use the query port and edit the existing server.
07-03-2011, 12:13 #4
- Mar 2011
- 2
ok thx guy's I didn't know that this is possible. In every tut i've seen so far, they change it in the server ini.
[solved] Changing server default port
By xfirefoxx in forum WindowsReplies: 2Last Post: 12-07-2010, 10:02 -
Changing the incoming server port?
By Sound Advice in forum Server SupportReplies: 11Last Post: 22-12-2009, 14:00 -
Server port keeps changing back to 8767 for all the servers i create
By roooii in forum [TeamSpeak 2] Server SupportReplies: 1Last Post: 08-01-2009, 14:37 -
Server will not start after changing port.
By RamataKahn in forum [TeamSpeak 2] Server SupportReplies: 5Last Post: 03-06-2003, 11:44 -
Changing port number of web admin tool doesn't work
By bragas in forum [TeamSpeak 2] Server SupportReplies: 2Last Post: 18-02-2003, 04:14
