Results 1 to 3 of 3
Thread: Volume Control Plugin
27-03-2011, 12:14 #1
-= TeamSpeak User =-
- Mar 2011
- 1
I'm using TS3, latest version; runinng Win 7 Home 64bit; USB headset (Sigma Tactic 3D).
I am completely unable to disable the Default Volume Control Plugin, I've tried disabling it via the checkbox, tweaking the settings between 0-100% to minimize the effect, hell - I even tried a reinstall but it's proved completely unresponsive.
Am I missing something simple here, or is there an underlying issue?
Thanks,
S.
27-03-2011, 16:23 #2
-= TeamSpeak Guru =-
- May 2010
- 6,372
What do you mean ?
If you uncheck this plugin, the volume, of the other applications, down again when someone talks on the teamspeak server ?
Do you try to run the Teamspeak client as "Admin" ?
When you write "latest version", do you mean the beta36 or RC1-pre11 ?
28-03-2011, 14:40 #3
-= TeamSpeak Team =-
- Jun 2008
- 7,764
I think it comes from Windows directly, when the plugin is disabled. Please check your playback device settings in windows. Ther should be a commounication tab. Select "do nothing" and it should work much better.
Or do you have an nforce audio card?---------------------------------------------------------
NPL License (Registration)
Problem with Volume control Plugin
By Fivetide in forum WindowsReplies: 2Last Post: 01-01-2011, 19:33 -
Defalt plugin: Volume Control Does not work.
By nipper4369 in forum PluginsReplies: 3Last Post: 28-01-2010, 18:57 -
volume control
By Bluheim in forum General QuestionsReplies: 0Last Post: 10-01-2010, 17:57
