Page 3 of 5 FirstFirst 12345 LastLast
Results 31 to 45 of 65
  1. #31
    Dec 2011
    Solved TS3 lows the sound of other programs in windows 7 when someone talk
    like the title says, that is what happen, Its kinda annoying im listening music and playing, and someone says something and sound lows, I would like to control that, when I want that to happen, and not teamspeak, I've tryed to go to sound options in windows 7 and tick option "do nothing" when someone talks but this is still happening, so this must be some problem from teamspeak, any1 can help pls?
  2. #32
    Dec 2011
    Romania
    Uninstal ts client go to appdata delete the "TS3Client" folder reinstal the client but do not check the box that says Enable Over.... or something like that .
    After this go to your sound manager -> right click -> recording devices ->
  3. #33
    Jan 2010
    Catalunya
    2,330
    Check if Volume Control is enabled in: Settings > Plugins > ...
  4. #34
    Dec 2011
    Thanks!!!!! It worked, finnally!
  5. #35
    Jan 2012
    Lightbulb In game sound
    When i have TS3 running and playing a game my sound gets lowered. Does anyone else have the same issue? How do you fix that? and when i stop usinf ts3 the sound works fine its only when someone talks on ts3.
  6. #36
    Jan 2010
    Catalunya
    2,330
    Check in ... Settings > Plugins ... if "Volume control" is enabled ?
  7. #37
    Jan 2012
    Sound reduced while talking in game
    I have windows 7 ulitmate 64 bit and when i am on TS3 while playing World of Tanks my volume goes to 20% in game sounds, sometime the sound returns to 100% and other times it stays at 20%. I have adjusted all volumes that i can find and it still does not work. Any help ??
    BiggPop
  8. #38
    Jan 2012
    Teamspeak volum in CS turns down
    Quote Originally Posted by s4lfish View Post
    Hi everybody,
    since the last major update of the ts3 client, i have the problem
    that when i am in teamspeak while i am playing Cs:Source an i use
    my ingame voice, the complete teamspeak lowers his volume.
    I've tested if this does relate to the hotkey that i use ingame tu use voice,
    but if a change the ingame hotkey the same problem appears.
    The only solution to rebuild the normal volume is to close teamspeak and
    open it again.
    I hope s.o. can help me with this.
    Regards
    Vannelle
    I had the same problem! I tryed playing around with the settings in TS but it did not work so i had a look in the CONTROL PANEL on my computer and played around and it fixed it so this is what i did.
    Contral panel-Hardwear and sound-sound-communications then click DO NOTHING and apply.
    I hope that helps.
  9. #39
    Feb 2012
    Volume control plugin causes game sounds to disappear.
    Teamspeaks plugin "volume control" lowered my game(mw3) sounds to almost null and they wont go up no matter what ill do. Don't know the tech how it lowers the sound (channel?) but I can't get the sounds up. Other sounds works fine, only the gamesound is really low.
    I have reseted the game, the machine various times and adjusted the sound in all menus I can find but nothing seems to help.
    Please help.
  10. #40
    Jun 2008
    Hamburg
    228
    The Volume Control Plugin lowers the volume slider for each application in your Windows Audio Mixer.
    So you should check the Volume Slider for mw3 in your audio mixer... i think it's set to almost zero and maybe disable the volume plugin right before you start mw3 again to be sure that the plugin don't lowers it again :P
    And you should also disable the windows side volume control. -> Control Panel -> Sound -> Communications -> Check "Do Nothing"
  11. #41
    Feb 2012
    Volume is jumpy
    well someone on my server will be talking and their volume will jump from loud to soft and its not my head set cause ive tried with both also ive redownloaded it so help?
    Thread has been merged
    It could be, that someone of your guys does have the permission "priority speaker" set.
  12. #42
    Feb 2012
    Quote Originally Posted by florian_fr40 View Post
    Check if the Volume Control plugin is activated
    Settings > Plugin
    i have and it is
  13. #43
    Jan 2010
    Catalunya
    2,330
    OK, then disable it
  14. #44
    Mar 2012
    Can't hear the gameplay sound when I start Teamspeak
    I am using the latest version of teamspeak. When I start teamspeak I can here my friends talking just fine but the game sound is very very faint. I turned up the game sounds in the in-game settings all the way. My volume is all the way up on my windows settings (windows 7 64bit) . I am using a headset. Any tips. Thanks
  15. #45
    Mar 2012
    TS lowering ingame sounds
    I have a little problem with my TS 3 client. I am using WIN7 32bit verion and in my sound settings- communication- i have checked no actionn. But everytime my sound get a luittle quiter in games.. I was playing with teamspeak settings aswell but no luck i wasnt able to find anything connected with my problem. how yould i fix this problem
  1. Replies: 3
    Last Post: 16-07-2011, 15:13
  2. Teamspeak lowers game volume When Someone Speaks
    By Bradd in forum General Questions
    Last Post: 14-12-2010, 19:53
  3. Replies: 7
    Last Post: 09-12-2010, 04:44
  4. Volume lowers longer they talk.
    By Seal_Clubr in forum Bug Reports
    Last Post: 24-04-2010, 19:58
  5. [Solved] My talking lowers others volume
    By royalflushxx in forum Windows
    Last Post: 08-02-2010, 23:09
