Results 1 to 7 of 7
    Jun 2011
    Default Port Change Problem
    I've watched several tutorials and still couldnt do it right
    tried it:
    use 1
    login serveradmin password
    serverstop sid=1
    use 1
    serveredit virtualserver_port=9988
    serverstart sid=1
    Problems
    root@xoranex:/opt/ts3# use 1
    -bash: use: command not found
    and
    root@xoranex:/opt/ts3# login serveradmin
    Password: ******
    Login incorrect
    tried it
    Server Query Admin Acccount created
    loginname= "serveradmin", password= "*******"
    Dec 2009
    New Jersey USA
    68
    Try it like this:
    use 1
    serverstop sid=1
    serverstart sid=1
    May 2010
    6,372
    xoranex, I already answer you in your first thread ( http://forum.teamspeak.com/showthrea...fault-Port-TS3
    Please no double post. And it's not necessary to send me a private message. Just post an answer in your thread.
    Quote Originally Posted by xoranex
    This is not a linux command, but a Teamspeak query command.
    You have to use the telnet command on your machine, directly on the query port.
    And please follow the query command step that I wrote
    Jun 2011
    I finally got, but now I want so
    COMMANDLINE_PARAMETERS="query_port=10222 default_voice_port=9999 ${2}" #add any command line parameters you want to pass here
    but dont worked :S please see problem
    i edit file:ts3server_startscript.sh
    Query port worked but default voice_port dont work :S
    May 2010
    6,372
    Quote Originally Posted by xoranex View Post
    It's normal because you have already start your server. The default is already created.
    So, let me repeat myself :
    1- Open a telnet pormpt on your linux system :
    telnet <ip> 10011
    2 - Use query command to change the port
    login serveradmin <password>
    use 1
    serverstop sid=1
    serverstart sid=1
    Quote Originally Posted by Florian
    If you don't read what we wrote to help you, it will become difficult
    Jun 2008
    7,764
    I guess the problem is, that the server is running.
    Please stop the virtual server and select it with use 1 -virtual and then edit the port.
    NPL License (Registration)
    May 2010
    6,372
    Basically these methods works both.
  1. [HELP] Change Default Port TS3
    By xoranex in forum Linux / FreeBSD
    Last Post: 02-06-2011, 12:28
  2. Cabt change Default Voice Port
    By coolruffy in forum Linux / FreeBSD
    Last Post: 20-12-2009, 18:17
  3. How change default port?? UPD
    By sereban in forum [TeamSpeak 2] Server Support
    Last Post: 27-09-2007, 19:14
  4. help change default port
    By FireBelly in forum [TeamSpeak 2] Server Support
    Last Post: 22-11-2004, 16:03
  5. change TS default port
    By cynicalscope in forum [TeamSpeak 2] Server Support
    Last Post: 01-06-2004, 10:39
