Results 16 to 30 of 36
11-08-2011, 16:49 #16
-= TeamSpeak Team =-
- Jun 2008
- Location
- Hamburg
- 228
Like ScP said > Our devs will investigate this issue asap. Thank you for reporting this!
-Internal TicketID:TS-622-
11-08-2011, 17:14 #17
-= TeamSpeak User =-
- Aug 2011
- Location
- Somwhere
- 11
weird. I'm also using a ps3 eye... D:
11-08-2011, 22:13 #18
- Aug 2011
- 2
So I'm i! D:
11-08-2011, 22:44 #19
- Aug 2011
- 3
Cheers, choosing direct sound option seems to have fixed the issue for now.
12-08-2011, 03:39 #20
- Aug 2011
- Location
- Somwhere
- 11
Not for me. It says error: could not open capture device. D:
12-08-2011, 05:36 #21
- Aug 2011
- 4
I have tried everything I can think of! This is soo frustrating! When I connect it shows that my speakers/headphones are disconnected. I also get the following message: "The configured playback device was not found. Instead using: Logitech USB Headset Press OK to apply the changes or press Setup to change the configuration manually." And everything I have tried has been useless! I get sound, just nothing through TS3.
13-08-2011, 00:59 #22
- Aug 2011
- 1
I am getting this error message when I try to get into a server.
Assertion channels==0 failed at client\clientlib\sound\sounddevicemanager.cpp:913;
Any help would be great. I am running vista and yes I have reintstalled twice!
16-08-2011, 18:21 #23
- Aug 2011
- 1
Client crash after selecting microphone
error message when i try to change my microphone from default to PS3 Eye
17-08-2011, 08:18 #24
- Jun 2008
- 7,764
You can test our fixed version through the beta channel
How to:
- Download the update.zip and unzip it.
- Now take the file called update.ini and put it in your client folder
Example
- Start the client and update your client per Help > Check for UpdateCode:C:\Program Files\TeamSpeak 3 Client
NPL License (Registration)
18-08-2011, 01:15 #25
- Aug 2011
- 1
thanks the beta seems to have fixed the problem for now.
19-08-2011, 18:42 #26
- Aug 2011
- Location
- Somwhere
- 11
But now it says "could not open capture device". D:
Hi all. For some reason, my PS Eye webcam doesn't work on ts3. I have checked my sound drivers (they are up to date), and seen if the camera needs an update. (It's also up to date.) I am running on a Windows Vista Home Premium x64, and my sound card is an HDMI High Definition Audio card. Please help.
My error message log is at the bottom.
2011-08-19 오후 1:51:20 Error VADDisplay timer: Error reading voice power: 2304
I didn't need to add anymore, because the same message appears about 6,000 times.
PLEASE HELP!
20-08-2011, 21:21 #27
- Aug 2011
- 1
Crashing from microphone
It was working fine before the update, now everytime i try and use my PSEyes microphone in teamspeak it crashes, when it works fine everywhere else
Code:Assertion channels==0 failed at client\clientlib\sound\sounddevicemanager.cpp:913;
22-08-2011, 07:43 #28
- Jun 2008
- 7,764
CrispyFries, do you use the beta update 3.0.1 now?
AuToFiRe please read the first post and update first.Last edited by dante696; 22-08-2011 at 09:07.
22-08-2011, 07:47 #29
- Jun 2002
- Location
- Netherlands
- 1,196
22-08-2011, 19:42 #30
- Aug 2011
- 1
TS3 Error | By changing the microphone
Hello!!
I have a ps3 webcam and i used it for ts3. Now when i want to speak with it, than always come this error message:
"Assertion channels==0 failed at client\clientlib\sound\sounddevicemanager.cpp:913; "
pls help me!
[Clientlib]onClientJoin Event
By willy_sunny in forum Suggestions and FeedbackReplies: 0Last Post: 18-04-2011, 20:20 -
ClientLib SDK with Delphi
By andi99762 in forum General QuestionsReplies: 1Last Post: 04-09-2010, 09:20 -
Failed to get channel of client in update client
By faralsimbor in forum Client SupportReplies: 0Last Post: 05-02-2010, 16:47
