Results 1 to 3 of 3
12-08-2011, 03:06 #1
-= TeamSpeak Lover =-
- Jan 2010
- Location
- Phoenix, AZ
- 85
GLIBC_2.9 not found, Centos 5 32bit
I have two Linux Centos 5 servers, one running 64bit and the other running 32bit.
ON the 64bit version I have been upgrading the client all along through the beta channel and everything has been fine and is working nicely.
On the 32bit version I am getting the following errors
This started some time during the beta release of rc1 or rc2 and I fell back to beta36 to fix the problem and waited for the final release.Code:./ts3client_linux_x86: /lib/libc.so.6: version `GLIBC_2.9' not found (required by ./libQtCore.so.4) ./ts3client_linux_x86: /lib/libc.so.6: version `GLIBC_2.9' not found (required by ./libQtGui.so.4) ./ts3client_linux_x86: /lib/libc.so.6: version `GLIBC_2.10' not found (required by ./libQtNetwork.so.4)
as of the final release, the same problem is still happening, and I have encountered another Centos server 5 running 32bit with the same problem.
In another thread about this same subject Peter talked about relinking the binaries with the correct GLIBC
Is it possible this needs to be done again ?
Or is there another solution.
GLIBC 2.9 is not available for this Centos release, and I'm not sure how involved it would be to install it. But the 64bit is working, so I'm thinking this is just an issue with your 32bit compile.
What other info can I get you ?
12-08-2011, 16:17 #2
-= TeamSpeak Addict =-
- Jan 2011
- Location
- US
- 266
I do not have this problem on my 32-bit. Did you yum install glibc*?
13-08-2011, 04:53 #3
- Jan 2010
- Location
- Phoenix, AZ
- 85
I upgraded to the latest version which is 0:2.5-58.el5_6.4
But it still doesn't work, either way the same version is running on the 64bit and working.
libc is linked to the 2.5 version on 32 and 64 bit
/lib/libc.so.6 -> libc-2.5.so*
So that makes me think it was linked with the wrong version on the 32 bit
[CentOS] libmysqlclient_15' not found
By channex in forum Linux / FreeBSDReplies: 4Last Post: 13-03-2011, 09:10 -
32bit vs X64
By Bad_Karma in forum Server SupportReplies: 3Last Post: 14-03-2010, 10:40 -
`GLIBC_2.2' not found (required by ./sqlite.so)
By ryana in forum [TeamSpeak 2] Server SupportReplies: 4Last Post: 02-04-2003, 13:46
