Results 1 to 7 of 7
Thread: TSDNS Help
14-08-2011, 19:24 #1
-= TeamSpeak User =-
- Jul 2011
- 13
TSDNS Help
I'm trying to teach myself how to run the tsdns server and I'm having some problems. My tsdns_settings.ini file reads:
bosgaming.info=internal ip (192.168.1.106):9877
ts3.bosgaming.info=internal ip (same as above):9877
*=internal ip:9877
I've tried changing the internal ip to the external ip with no luck. The server does start saying "Scanned tsdns_server.ini, number of entries: 3
Any help?
My system is CENTOS 6.0Last edited by MavRicBoS; 15-08-2011 at 00:08.
10-09-2011, 17:58 #2
- Jul 2011
- 13
I've switched to a hosted server and still cannot get this to work. Can someone please post their working config file for TSDNS?
11-09-2011, 07:23 #3
-= TeamSpeak Guru =-
- May 2010
- 6,372
You can't use a non routable IP on Internet (non routable=192.168.x.x this kind af IP is restricted to a private network only).
Also, the TSDNS server must be reachable by bosgaming.info (in other word, the bosgaming.info's IP must be the same of the machine where is the TSDNS server).
11-09-2011, 10:13 #4
- Jul 2011
- 13
I moved my test server to a hosting server. My new address is someserver.com and I tried to get TSDNS to work, and trying to connect to bosgaming.com without the port does not work.....
12-09-2011, 07:42 #5
- May 2010
- 6,372
Make a point:
On the server where point the bosgamers.com domain, there is the TSDNS server, right ?
And the Teamspeak server is on the same machine ?
12-09-2011, 08:33 #6
- Jul 2011
- 13
Thanks for the reply florian_fr40. This problem is solved. My hosting provider had to open port 41144 tcp in and out in order for the tsdns server to listen for incoming ts requests.
12-09-2011, 11:16 #7
- May 2010
- 6,372
Yes it was my next question
TSDNS problem
By Tiranous in forum Client SupportReplies: 3Last Post: 21-07-2011, 00:53 -
tsdns help!
By thesamu in forum Linux / FreeBSDReplies: 7Last Post: 13-07-2011, 21:46 -
[Resolved] TSDNS Service
By Kekskind1992 in forum WindowsReplies: 8Last Post: 12-07-2011, 21:42 -
TSDNS problem
By erikz in forum Linux / FreeBSDReplies: 4Last Post: 15-06-2011, 19:52
