Results 1 to 3 of 3
Thread: Input audio problem
30-08-2011, 00:40 #1
-= TeamSpeak User =-
- Jan 2011
- 2
Input audio problem
the microphone is working with every other application, but not on teamspeak. Changing input on Settings->Options-> Capture has no effect. there is nother other sound probleme.
i've tried to remove ts3 conf (/home/xxx/.ts3client), and run another installation of teamspeak, without any change.
Here is the log when i launch teamspeak3 without the launcher (i tried that to have more information that Tools->Client_log).
any idea ?Code:2011-08-30 01:32:00.492982|INFO |MPSingleton | | Detected local codeset to be: UTF-8 2011-08-30 01:32:00.494944|INFO | | | Logging started, clientlib version: 3.0.1 [Build: 15001] 2011-08-30 01:32:00.553095|DEBUG |PulseAudio | | connected to pulse audio server 2011-08-30 01:32:00.568272|INFO | | | Api version is not compatible for plugin: /home/xxx/Téléchargements/TeamSpeak3-Client-linux_x86/plugins/doodle.so 2011-08-30 01:32:00.577806|INFO |Query | | listening on 127.0.0.1:25639 2011-08-30 01:32:00.578657|INFO | | | Registering plugin command id: {103b6f92-018f-4557-9910-50042928d0d2} clientquery_plugin LUA_PLUGIN: init Initializing Lua interpreter 2011-08-30 01:32:00.601371|INFO | | | Registering plugin command id: {3aedb3c8-9910-4457-9021-1797ef7918a5} lua_plugin LUA_PLUGIN: registerPluginID: {3aedb3c8-9910-4457-9021-1797ef7918a5} ClientQueryPlugin: currentServerConnectionChanged 1 (0) 2011-08-30 01:32:01.361536|INFO |ClientUI | | Failed to init text to speech engine 2011-08-30 01:32:01.362047|INFO |ClientUI | | TeamSpeak 3 client version: 3.0.1 [Build: 15001] 2011-08-30 01:32:01.362324|INFO |ClientUI | | Qt version: 4.7.2 2011-08-30 01:32:01.362587|INFO |ClientUI | | Using configuration location: /home/xxx/.ts3client/ts3clientui_qt.conf 2011-08-30 01:32:01.939882|INFO |ClientUI | | Last update check was: mar. août 30 00:00:06 2011 AA ts3.alsa.dummy.playbackdefault 5 warning: Unknown nb_ctl request: 12 2011-08-30 01:32:19.385110|INFO |PreProSpeex | 1| Speex version: 1.2rc1 warning: The VAD has been replaced by a hack pending a complete rewrite warning: Unknown nb_ctl request: 12 warning: The VAD has been replaced by a hack pending a complete rewrite QFSFileEngine::open: No file name specified
thanks for the help.
01-09-2011, 13:04 #2
- Jan 2011
- 2
Problem solved
02-10-2011, 21:37 #3
- Oct 2011
- 1
Hi, I have the same problem please help
Select Left/Right Channel of Audio Input Source
By MeisterM in forum Client SupportReplies: 1Last Post: 10-11-2010, 13:04 -
Parallel audio input and output.
By wolfpics in forum [TeamSpeak 2] Client SupportReplies: 1Last Post: 13-06-2009, 00:19 -
TS2 reset my audio input/output settings when started
By rigsta in forum [TeamSpeak 2] Client SupportReplies: 2Last Post: 28-10-2008, 20:53 -
Input Muted Problem
By Afghan in forum [TeamSpeak 2] Server SupportReplies: 0Last Post: 01-03-2003, 20:50
