Results 1 to 6 of 6
    Sep 2011
    Solved NPL License Problem
    Hello ich have a problem with my NPL license i have put the licensekey.dat in my ts3 folder but the server log says:
    2011-09-27 14:48:40.843750|INFO    |ServerLibPriv |   | Server Version: 3.0.0 [Build: 14957], Windows
    2011-09-27 14:48:40.843750|INFO    |DatabaseQuery |   | dbPlugin name:    SQLite3 plugin, Version 2, (c)TeamSpeak Systems GmbH
    2011-09-27 14:48:40.843750|INFO    |DatabaseQuery |   | dbPlugin version: 3.7.3
    2011-09-27 14:48:40.843750|INFO    |DatabaseQuery |   | checking database integrity (may take a while)
    2011-09-27 14:48:40.906250|INFO    |SQL           |   | pruning old database log entries where timestamp is older than 90 days
    2011-09-27 14:48:40.937500|WARNING |Accounting    |   | Unable to find valid license key, falling back to limited functionality
    2011-09-27 14:48:40.984375|INFO    |FileManager   |   | listening on 0.0.0.0:30033
    2011-09-27 14:48:41.187500|INFO    |VirtualServer |  1| listening on 0.0.0.0:9987
    2011-09-27 14:48:41.187500|INFO    |CIDRManager   |   | updated query_ip_whitelist ips: 127.0.0.1,
    2011-09-27 14:48:41.187500|INFO    |Query         |   | listening on 0.0.0.0:10011
    2011-09-27 15:00:14.671875|INFO    |GetWanIP      |   | WAN ip: xx.xxx.xx.xx
    2011-09-27 15:00:15.562500|INFO    |VirtualServer |  1| stopped
    i hope someone can help me.
    May 2010
    6,372
    Did you used a tool to get your mail or you use the webmail from your provider ?
    Do you use a start parameter to start your teamspeak server ?
    In some cases you have to wait 2/3 hours before restart your server with the license.
    Sep 2011
    i use the webmail and i don't use start parameters. I will wait 3 hours and if the problem still there i will reply.
    May 2010
    6,372
    hum, if you edit your license file (e.g. notpad++) do you see your information with a key or just a key ?
    Also, you can use the "Resend license mail" option (on Teamspeakusa website). Maybe the first a problem occured.
    Sep 2011
    i see my information and the key
    okay i have found the problem my Mac has renamed it to license key.dat.txt
    i have re saved is as a .dat file.
    thanks for the support
    May 2010
    6,372
    Good
    Next time, don't forget to specify this kind of thing in your first message
  1. Problem with NPL License
    By deeforgotten in forum Server Support
    Last Post: 18-07-2011, 10:19
  2. license.dat problem
    By ATMka in forum Linux / FreeBSD
    Last Post: 06-12-2010, 14:25
  3. Problem with license key?
    By Sorris in forum Windows
    Last Post: 30-11-2010, 16:36
  4. License key problem
    By aaronds in forum Linux / FreeBSD
    Last Post: 25-10-2010, 19:28
