Results 1 to 2 of 2
    Sep 2011
    licensekey.dat doesn't work
    licensekey.dat
    Server has been shut down: Server Shutdown!
    type : Nonprofit
    start date : Fri Jul 29 00:00:00 2011
    end date : Sun Jul 29 00:00:00 2012
    max. virtual servers: 10
    max. slots : 512
    2011-09-27 16:24:34.743012|INFO |ServerLibPriv | | Server Version: 3.0.0 [Build: 14957], Linux
    2011-09-27 16:24:34.743268|INFO |DatabaseQuery | | dbPlugin name: SQLite3 plugin, Version 2, (c)TeamSpeak Systems GmbH
    2011-09-27 16:24:34.743301|INFO |DatabaseQuery | | dbPlugin version: 3.7.3
    2011-09-27 16:24:34.743592|INFO |DatabaseQuery | | checking database integrity (may take a while)
    2011-09-27 16:24:34.771440|INFO |SQL | | pruning old database log entries where timestamp is older than 90 days
    2011-09-27 16:24:34.785188|WARNING |Accounting | | Unable to find valid license key, falling back to limited functionality
    2011-09-27 16:24:34.805961|INFO |FileManager | | listening on 0.0.0.0:30033
    2011-09-27 16:24:34.806703|ERROR | | | TS3ANetwork::ResolveHostName failed error: -3 (Temporary failure in name resolution) 11
    2011-09-27 16:24:34.806854|ERROR | | | Could not open default UDP connection for weblist
    May 2010
    6,372
    About the license file
    - Do you put it in the server log ?
    - Do you use a start parameter to start your server ?
    - Please post the result of "ls -al"
    About the TS3ANetwork error
    - Please be sure that the port 53 is open (tcp/udp - input/output).
    About the UDP connection error
    - Please be sure that the port 2010 (UDP - output) is open.
  1. [Resolved] Licensekey expired
    By alboo in forum Server Support
    Last Post: 23-08-2012, 14:20
  2. licensekey problems
    By tebek in forum Windows
    Last Post: 09-06-2011, 15:01
  3. Non-profit licensekey
    By Devial in forum Server Support
    Last Post: 21-02-2011, 21:31
  4. [No Bug] Licensekey.dat
    By chris_pl in forum Linux / FreeBSD
    Last Post: 24-01-2011, 18:49
  5. Licensekey wont work
    By Uruk-h4j in forum Windows
    Last Post: 22-06-2010, 13:29
