Results 1 to 3 of 3
    Jul 2011
    18
    Snaphotdeploy Problem TS3
    Ok the question is that i had a TS3 in other adress i mean in a diferent host, And with th server query panel i made a lot of copies with the command servernapshotcreate and that work normally without problems and i copy all in a .txt files and in this moment when i put the command serversnapshotdeploy and all .txt i have a problem because when i want to deploy it appear me this error:
    rror id=0 msg=ok (54 ms)
    error id=516 msg=invalid\sclient\stype (55 ms)
    Total: 109 ms
    So i want that you help me here a SS:
    http://i56.tinypic.com/fp1e8j.jpg
    I hope that you can helpme thx for all...
    Oct 2003
    2,296
    The answer is simple. Snapshots cannot be deployed via client-side ServerQuery. Use a TCP connection to the ServerQuery interface instead.
    Jul 2011
    18
    Ok thanks a lot, But i have a question or a request can you explain me how can i do that? Because i want like a tutorial to use deploy via interface if you can help me will be gratefully to me
    Thx
