Results 1 to 3 of 3
Thread: Weird server problem
12-11-2011, 02:59 #1
-= TeamSpeak User =-
- Nov 2011
- 1
So I've setup a TS3 64 bit server on my old computer (Vista 64 bit).
I've forwarded the ports, as per instructions. The port is the default 9987. I've enabled the TS3 server to bypass the windows firewall. I can connect to the server from the local host machine with the TS3 client.
Now when I try to connect from another computer (while using my external IP address), the TS3 client says "Failed to connect to server". Thats it.
If I open up the Server List, it shows up in the list, but it wont connect to the server.
Any ideas whats the cause, or anything I should try?
12-11-2011, 10:09 #2
-= TeamSpeak Addict =-
- Apr 2011
- Location
- Germany
- 286
Sounds like your port forwarding is not forwarding properly.
You might want to double check the settings on you router.
Barungar
13-11-2011, 14:11 #3
-= TeamSpeak Guru =-
- May 2010
- 6,372
If you other computer is on your home network, it's normal. You can't use your EXTERNAL IP to return on your HOME network.
Also, please make sure that the port 9987 is formard in UDP mode only.
Really weird problem: No reply from server
By Trekz in forum [TeamSpeak 2] Client SupportReplies: 3Last Post: 29-03-2009, 23:40 -
Weird problem regarding my server
By dd_dpa in forum [TeamSpeak 2] Server SupportReplies: 7Last Post: 08-07-2007, 07:20 -
By BlackKnight35 in forum [TeamSpeak 2] Server SupportReplies: 5Last Post: 05-10-2004, 04:14 -
Weird problem with TS2 RC2
By Devilish in forum [TeamSpeak 2] Client SupportReplies: 0Last Post: 06-06-2003, 18:54
