Results 1 to 15 of 24
26-02-2012, 19:38 #1
Insufficient Permission Modify Power as Server Admin
Hello @ all!
Sorry, if my english isn't so good, but i had bad teachers...
I am from germany and i have a little permission problem.
I had to create a new TeamSpeak 3 Server and so i copied the sqlitedb-file to the new home-directory of my new server. I've also copied the "Non-Profit License" to the home-directory.
But i have two problems...
The first problem is, that the server isn't shown in the "server list"...
And the second one - which is very important - is, that i am one server admin of the server group. I would change some permissions of my client und a group, but TeamSpeak says, that i haven't got the permissions to do that...
For example: I wanna add a permission...
I haven't got any experience with the server query, so if i must work with it: Explain it step-by-step please! Thank you very much!
Originally Posted by TSł Server
Can somebody help me, to resolve my issue?
Thanks,
Sebi
The TSł-Server is running on a Linux Debian system. (I have "Server Admin" rights and i am the owner/hoster of the server.)
My TSł-Client is running on a Windows 7 system.Last edited by Sebi94; 26-02-2012 at 19:49.
26-02-2012, 19:54 #2
-= TeamSpeak Fanatic =-
- Jan 2010
- Location
- Catalunya
- 2,330
Have you checked this option?The first problem is, that the server isn't shown in the "server list"...
Tools > Edit Virtual Server > Misc (tab) > "Enable reporting to server list"
Take a look in this post: http://forum.teamspeak.com/showthrea...t-aid-quot-kitinsufficient permission modify power
26-02-2012, 20:00 #3
Very nice thread, but it doesn't help me.
What exactly must i write, that i get my permissions, to do all on my server?
It is enabled, but greyed out...Last edited by Sebi94; 26-02-2012 at 20:19. Reason: EDIT: +Very nice...
26-02-2012, 21:31 #4
- Jan 2010
- Location
- Catalunya
- 2,330
1- About server list.
Is greyed but is checked, then is right
Don't forget open this port: weblist port (UDP out): 2010
You need wait some minutes, and remember, that in the general list, there aren't all the servers, only 100 randomly.
If yours doesn't, you should use the filters.
2-Permissions.
What permission you tray to change, when you get this error message?
26-02-2012, 21:56 #5
26-02-2012, 22:01 #6
- Jan 2010
- Location
- Catalunya
- 2,330
NO, you don't need forward this port, you must open this port in your firewall in out side
About permissions: Right click on your user name > Permissions > Permissions overview > Export as PDF ... and post here this pdf.file
26-02-2012, 22:13 #7
26-02-2012, 22:29 #8
- Jan 2010
- Location
- Catalunya
- 2,330
You can use ServerQuery:
Code:login serveradmin <password> use sid=<server_ID> or use port=<voice_port> servergroupaddperm sgid=6 permid=17310 permvalue=75 permnegated=0 permskip=0
27-02-2012, 11:43 #9
27-02-2012, 14:30 #10
- Jan 2010
- Location
- Catalunya
- 2,330
In the first installation of the server, you get the serveradmin password.
But if you lost it, you can retrieve it, reading this post: http://forum.teamspeak.com/showthrea...word-Look-here!
If is your first virtual server and you don't changed anything, sid=1 and port=9987, you can use either.
27-02-2012, 16:54 #11
- Jan 2010
- Location
- Secret Base in Arctic Region
- 1,188
Hm, according to the *.pdf there seem some permissions and values missing in your groups.
(Me is doing now like master florian did
) - If you want send a pm with the database file or a link to it and me will see to "repair" it.
27-02-2012, 19:46 #12
Ah, okay.
Thanks for your help! I created the whole server new, but i have a permission problem with the grants.
I created a new server group names "Super Server Admin". I want, that this Admin can do all - ignoring bans, passwords, create and delte anything, etc..
And the "normal 'Server Admin'" should can do the same, but a little bit less. That work's...
But i want following: Each server group rank can add a lower member to each group, until his own group.
Example:
~ Ranking
Super Server Admin (75)
Server Admin (70)
Member (50)
Guest (25)
~ Who can ranking who...
Server Admin can add "Guest" and "Member" to the Server-Group "Guest", "Member" and "Server Admin", BUT NOT to the "Super Server Admin"-Group.
The "Super Server Admin" should can add each client, to each Server-Group - also to his own Server-Group (Super Server Admin).
And the deleting out of a server-group should work also so.
Can there somebody help?
27-02-2012, 20:30 #13
- Jan 2010
- Location
- Catalunya
- 2,330
i_group_needed_member_add/remove_power~ Who can ranking who...
Super Server Admin.... 75
Server Admin............. 70
Member.................... 70
Guest....................... 70
i_group_member_add/remove_power
Member.................... 0 .... or remove permission
Guest....................... 0 .... or remove permission
27-02-2012, 20:49 #14
Thanks, but it doesn't work, cause of:
Originally Posted by TSł-Server
27-02-2012, 20:55 #15
- Jan 2010
- Location
- Catalunya
- 2,330
Who get this error, SuperServerAdmin or ServerAdmin ?
Post his permissions overview *.pdf
[Resolved] Channel admin cannot set subscribe power: insufficient permission modify power
By Westingham in forum Permission SystemReplies: 5Last Post: 24-02-2012, 08:40 -
Server Admin - Yet 'insufficient permission modify power'
By guitar112993 in forum Permission SystemReplies: 3Last Post: 03-09-2011, 22:40 -
insufficient permission modify power As Server Admin
By Lt-Fighter in forum General QuestionsReplies: 2Last Post: 06-08-2011, 09:03 -
Admin Server Query - insufficient permission modify power
By Mactabilis in forum General QuestionsReplies: 15Last Post: 27-08-2010, 16:40 -
By Brennan in forum Permission SystemReplies: 2Last Post: 15-05-2010, 19:30
