Results 1 to 10 of 10
    Mar 2012
    12
    Security issue with Token System?
    i have a Security Question about Server Tokens.
    I'm use a MySQL TS3 Server on Debian Squeeze 6.
    To join in user group normal (ID:7) the peoples can order automaticly a Token(Key).
    It works perfectly, with registration questions & IP.
    But now, some peoples say me, this is a really big Security issue?
    Can you confirm this or help?
    May 2010
    6,369
    If you allow all users to create a token (to get another groups with other permissions) yes it could be.
    Mar 2012
    12
    The users have no permission to create tokens.
    Only the php script create a simple token, without any SQL Injection options.
    The token is only, to add him in group 7, normal.
    is this also no security issue?
    its the same as, if i give an guest token for group normal.
    May 2010
    6,369
    I guess your php script use the query commands.
    So if you normal group is correctly set (kick, ban, add_member_remove, etc, etc) for me there is no security issue here.
    Mar 2012
    12
    Thanks for answers.
    My PHP Script uses only
    INSERT INTO `tokens` ..
    May 2010
    6,369
    NEVER MAKE A CHANGES DIRECTLY ON THE DATABASE (we never repeat it enough )
    You have the tokenadd query command for that.
    Mar 2012
    12
    How?
    tokenadd?
    Where i can find these commands
    EDIT:
    I found it, but how i can connect from php to server query?
    May 2010
    6,369
    You have two main possibilities:
    - The TS3 PHP Framework : http://addons.teamspeak.com/director...Framework.html
    - The TS3 Admin Class : http://addons.teamspeak.com/director...s-for-PHP.html
    You could make a simple search on google about the php and socket
    Mar 2012
    12
    Im try'd now the TS3 Admin Class, i set all options, but if im visit the PHP Script i got a error:
    500 Internal Server Error :s
    May 2010
    6,369
    Please use this thread to report any problem or question : http://forum.teamspeak.com/showthrea...n.class-v0.5.x
  1. tokens or set server group ?
    By Themouse in forum Permission System
    Last Post: 09-03-2010, 05:02
  2. password/tokens
    By jonnie-it-is in forum General Questions
    Last Post: 18-01-2010, 10:43
  3. Question about tokens
    By HakuAnime in forum General Questions
    Last Post: 02-01-2010, 16:10
  4. Question about tokens
    By mvdstroom in forum Permission System
    Last Post: 01-01-2010, 15:25
  5. tokens
    By tgcsniper in forum Windows
    Last Post: 25-12-2009, 03:43
