Results 1 to 3 of 3
30-03-2012, 16:15 #1
-= TeamSpeak User =-
- Mar 2012
- 2
[not possible] How to change audio codec to GSM
Hello;
Sorry if its widely asked question. I am new to these audio chat servers and trying to get and administer one now for my kin. I was reading a bit about changing audio codecs. But I do find only a few options when I go to edit channel (Low,Narrow and Ultra band speex with CELT mono). I do not find option to change it to GSM. Is this something thats specified at server side? Should I contact the people from whom I bought this? Or am I looking in the wrong place?
I saw in voipservers page that TS3 supports a lot of codecs and hence was ttrying to test which one suits all of us together the best. Not sure whether its specific to ts3 servers bought through voipservers; but was just wondering.
Thanks!
30-03-2012, 17:15 #2
-= TeamSpeak Fanatic =-
- Jan 2010
- Location
- El Prat de Llobregat (Barcelona, Spain)
- 1,288
Hello.
The codecs used by TS3 appear in this FAQ:
http://support.teamspeakusa.com/inde...-are-supported
In your case, the web page of your provider says "The following codec run-down comes direct from Teamspeak’s Official FAQ" but the link he provides as origin corresponds to the TeamSpeak 2 codecs. It's not a correct reference.
Greetings.
30-03-2012, 17:36 #3
- Mar 2012
- 2
That helps thanks a lot; by default it is at ultraband speex and its good; maybe I will try with CELT and see how it goes for all and then decide. This makes less options to try and simpler.
[Vista] SigmaTel High Definition Audio CODEC - Kein Sound im TS
By bobbymarley in forum [TeamSpeak 2] Client SupportReplies: 1Last Post: 10-09-2008, 14:46 -
Stuttering audio via Bluetooth headset due to audio init bug
By directhex in forum [TeamSpeak 2] Client SupportReplies: 1Last Post: 19-05-2006, 17:55 -
Audio Codec For current Teamspeak & TS3
By Gamma in forum [TeamSpeak 2] General QuestionsReplies: 12Last Post: 04-11-2004, 03:10 -
Audio codec
By nebula1 in forum [TeamSpeak 2] General QuestionsReplies: 1Last Post: 05-09-2004, 12:49 -
default audio codec
By onlineuser in forum [TeamSpeak 2] Server SupportReplies: 0Last Post: 13-12-2003, 10:00
