Results 1 to 4 of 4
    Apr 2012
    Noob needing help
    Ok. how do I find my server on the serve list? and how can I change the name from "TeamSpeak ]I[ Server"
    Edit: I have the free server
    Jan 2010
    1,286
    Hello.
    To change the name of the server:
    On the top of the channel tree, right clic on the name of the server --> Edit virtual server --> Fill in the "Server Name" field
    Important: once you are in the "Edit virtual server" --> "Misc" Tab --> Verify that "Enable reporting to server list" is enabled.
    Once you have changed the name, then it will be easier to find it in the server list.
    Greetings.
    Apr 2012
    Thanks! now it says 'Failed to connect to server' when I try to connect from the server list.
    Jan 2010
    1,286
    Hello.
    If the client and the server are behind the same router and the public ip fails then use the local ip for connect from the client.
    Use Bookmarks, and define one entry with the local ip and another with the public ip (that appears in the server list). Try to connect first with the public and after with the local.
    Greetings.
  1. needing to know
    By JLbayli947 in forum [TeamSpeak 2] Client Support
    Last Post: 02-05-2009, 09:52
  2. Needing a TS channel view
    By ·Cē· RecoN in forum [TeamSpeak 2] Addons & Scripts
    Last Post: 26-05-2005, 22:52
  3. New needing help
    By stol in forum [TeamSpeak 2] Client Support
    Last Post: 02-04-2004, 16:02
  4. Newbie needing help
    By os2 in forum [TeamSpeak 2] Server Support
    Last Post: 05-01-2004, 22:34
  5. Newbie needing to run 24/7 server
    By Lynx in forum [TeamSpeak 2] Server Support
    Last Post: 03-03-2003, 20:05
