Results 1 to 4 of 4
    Apr 2012
    [PROBLEM]Teamspeak on mysql
    Hi.
    I have a problem when starting the mysql server.
    root@kierzek2:/home/test# ./ts3server_minimal_runscript.sh dbplugin=ts3db_mysql dbsqlcreatepath=create_mysql/
    2012-04-18 14:08:46.182728|INFO    |ServerLibPriv |   | TeamSpeak 3 Server 3.0.3 (2012-03-17 06:12:11)
    2012-04-18 14:08:46.183088|INFO    |DatabaseQuery |   | Please make sure you use the supplied ts3server_minimal_runscript.sh to run the server, or set LD_LIBRARY_PATH yourself
    2012-04-18 14:08:46.183121|CRITICAL|DatabaseQuery |   | unable to load database plugin library "libts3db_mysql.so", halting!
    My ts3db_mysql.ini
    [config]
    host=localhost
    port=3306
    username=ts3
    password=my_password
    database=ts3
    socket=
    Please help me.
    by
    May 2010
    6,372
    What is your linux distrib to merged your thread with the good one.
    Please note : this question has been answered many times on this forum. Next time please use the forum search function.
    Apr 2012
    Debian 6, I was looking for but not worked it out
    Mar 2012
    18
    Quote Originally Posted by kierzek View Post
    Here s my guide to set up ts3-server under debian 6
    If shortly, you don't have libmysqlclient.so.15 (Debian Squeeze has libmysqlclient.so.16)
    :~# ldd /usr/lib/ts3-server/libts3db_mysql.so
    linux-vdso.so.1 => (0x00007fff06399000)
    libmysqlclient.so.15 => /usr/lib/libmysqlclient.so.15 (0x00007fb95643b000) You will get an error here
    libstdc++.so.6 => /usr/lib/libstdc++.so.6 (0x00007fb956127000)
    libm.so.6 => /lib/libm.so.6 (0x00007fb955ea4000)
    libgcc_s.so.1 => /lib/libgcc_s.so.1 (0x00007fb955c8e000)
    libc.so.6 => /lib/libc.so.6 (0x00007fb95592c000)
    libpthread.so.0 => /lib/libpthread.so.0 (0x00007fb95570f000)
    libcrypt.so.1 => /lib/libcrypt.so.1 (0x00007fb9554d8000)
    libnsl.so.1 => /lib/libnsl.so.1 (0x00007fb9552c0000)
    libz.so.1 => /usr/lib/libz.so.1 (0x00007fb9550a8000)
    /lib64/ld-linux-x86-64.so.2 (0x00007fb956a52000)
    Go to http://packages.debian.org/ru/lenny/libmysqlclient15off
    And get a file fo your arch
    wget http://ftp.us.debian.org/debian/pool/main/m/mysql-dfsg-5.0/libmysqlclient15off_5.0.51a-24+lenny5_amd64.deb
    sudo dpkg -i ./libmysqlclient15off_5.0.51a-24+lenny5_amd64.deb
  1. Teamspeak und MySQL Problem!
    By g4x90 in forum [TeamSpeak 2] Server Support
    Last Post: 25-11-2009, 17:51
  2. MySQL Problem with Teamspeak
    By stewie316 in forum [TeamSpeak 2] Server Support
    Last Post: 03-06-2008, 23:56
  3. Problem with Teamspeak & MySQL
    By Yeppa in forum [TeamSpeak 2] Server Support
    Last Post: 05-09-2007, 14:08
  4. Problem mit Teamspeak und MySQL
    By toniguenther in forum [TeamSpeak 2] Server Support
    Last Post: 07-03-2005, 17:57
